how do you remove the bose headunit from a 1996 4th gen maxima?
Old Feb 3, 2008 | 05:43 PM
Holty's Avatar
I don't know, maybe i'm blind but i've found a "how to" on removing the head units for all the different generations of maximas except for the 4th gen. I need a step by step (preferably with pictures) tutorial of how to remove a stock bose head unit from a 1996 Maxima. I've just spent the last 2hrs searching this forum, the faq's dead or wrong links, and tech articles on various car audio sites. I am coming up empty. Can anyone help me out?
Old Feb 3, 2008 | 07:24 PM
komik's Avatar
- Remove trim panel around shifter
- Unplug cigarette lighter if necessary
- Remove one screw and pull ashtray out, set aside
- Pull bottom of trim piece holding hazard / defog buttons and upper vents (pops out). The directions I read said to remove it completely, mine comes out enough at the bottom to reach the screws behind it.
- Remove four screws (two top, two bottom) to release CC & radio assembly.
- Pull assembly away from dash.
- Unplug all wiring harnesses / antenna wires.
- Flip assembly over and remove four screws holding the trim panel to the metal bracket.
- Remove screws on each side of radio (mine only had two, but it had been removed before, so there may be more) holding radio to bracket.
- Pull radio out through front of bracket.
Old Feb 7, 2008 | 06:00 PM
Snypa's Avatar
insturction above is pretty good.yep..thats it.
Old Feb 8, 2008 | 08:23 AM
WillMax01's Avatar
If it's not too late, since you had trouble finding a post about it, you should take pictures and do your own write-up to help other people out...just an idea.
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
morteljc
Oct 19, 2015 10:47 AM
Finkle
Sep 27, 2015 09:53 PM
