Intake plenum and cooling fluid
Old Feb 11, 2008 | 04:33 AM
redwood_usa's Avatar
I normally do drain the cooling fluid , but do I have to when I take the upper plenum off ?? or is it above the static level.
Old Feb 11, 2008 | 05:44 AM
Mike90SE's Avatar
You might not have to drain all of it, but I would drain at least 1/2 just to be safe. Someone correct me if I am wrong.
Old Feb 11, 2008 | 08:49 AM
Matt93SE's Avatar
STFU n00b!
For VG or VE?
the VG has some coolant in it, but I didn't bother draining the system- just pulled the hoses off and let the small bit dribble out. keep the hoses propped up though- if you bend them down and out of the way, they'll siphon out coolant until the level is as low as the end of the hose.
for the VE, there's no coolant passages in the IM, except for the one going through the throttle body.
Old Feb 11, 2008 | 08:53 AM
Originally Posted by Matt93SE
For VG or VE?
VG , and I will be keeping the throttle on the car (disconnecting it from the plenum.)
Old Feb 11, 2008 | 08:59 AM
Greeny's Avatar
¯\(°_o)/¯
Why?,you will just have to buy another gasket then. It would be easier to remove the intake as a whole.
Old Feb 11, 2008 | 10:16 AM
got to clean the throttle body anyhow. what I meant was that I would leave the elbow behind. so I wouldn't be removing the coolant hoses there and therefore wondered if I could save my lazy as some work by not draining the coolant first.
Old Feb 11, 2008 | 11:11 AM
Matt93SE's Avatar
STFU n00b!
not that lucky on the VG.
there's coolant running through both the TB and the intake mani on the VG.
Old Feb 11, 2008 | 12:43 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yep the coolant goes into (or out of... can't remember) a port just below the pcv valve hookup and there's another one somewhere else that is the outlet (or inlet, depending which direction it flows, since i forgot by now) that you have to disconnect as well. they are fairly close to each other, ie, maybe 4 inches apart.
Old Feb 11, 2008 | 02:31 PM
Thanatos's Avatar
For VG or VE?
noob question. why does the tb have a coolant line. i wouldnt think it would need one.can they be diconnected. if so would it be a benifit to disconnect.
Old Feb 11, 2008 | 02:45 PM
internetautomar's Avatar
mod or sell?
coolant lines to the TB are to keep it from icing up.
Old Feb 11, 2008 | 03:03 PM
Thanatos's Avatar
would it make any sense to block it off during summer months to keep it cooler.
Old Feb 11, 2008 | 03:08 PM
Greeny's Avatar
¯\(°_o)/¯
I've had my tb coolant lines blocked on my VE for many years,no problem where we live.
Old Feb 11, 2008 | 03:34 PM
gapboi210's Avatar
I hear the coolant lines in the TB are an emissions thing to help the warm the air and motor asap. I dunno
Old Feb 11, 2008 | 04:18 PM
Pearl93VE's Avatar
I can has?
Nah, It's more of a precautionary thing so in colder climates (Sub Freezing) your butterfly plate doesn't get stuck open/closed.
Old Feb 11, 2008 | 04:57 PM
Matt93SE's Avatar
STFU n00b!
it does a bit of all of the above. it's there for more than one single reason.. but it really doesn't make a difference in how the car drives. I noticed no difference when I did it on my car.
Old Feb 11, 2008 | 09:00 PM
me either. my gas pedal is the smoothest travelling pedal i've ever stepped on. even my mom's 99 camry 2.2 has a notchy pedal.. even AFTER i thoroughly cleaned the TB on it. and her coolant thingy still goes through her TB. or so i assume. i assume that engine has that feature.
anyhow, i have no coolant flowing through my TB or my UIM. and have noticed no harm. car still squeals tires off a light with a slushbox so i'm happy.
Old Feb 12, 2008 | 09:02 AM
Alex_V
I had my 240's throttle body coolant bypassed last year when I lived in chicago over the winter, no problems at all.
Best thing to do is keep it clean with a old tooth brush, carb cleaner and a rag/paper towels.
~Alex
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
fastcarny
Oct 12, 2015 07:06 AM
pears
Sep 18, 2015 05:25 AM
Mahmuth
Sep 17, 2015 11:45 AM
Maxboy23
Sep 9, 2015 10:37 AM
