98 Maxima SE - Using Oil
I have a 98 Maxima SE with 60,000 miles on it and it uses about 2 quarts of oil every 3,000 miles. It doesn't appear to be burning it and I haven't noticed any leaks on my driveway. Does anyone know what could be causing this????
[Edited by COOPE87545 on 11-03-2000 at 09:55 AM]
Originally posted by COOPE87545
I have a 98 Maxima SE and it uses about 2 quarts of oil every 3,000 miles. It doesn't appear to be burning it and I haven't noticed any leaks on my driveway. Does anyone know what could be causing this????
The two major reasons for burning oil are worn valve seals and worn piston rings.
Your concern about oil consumption is understandable, but manufacturers typically say that one quart per 1000 miles is considered acceptable. A "tight" engine will use less oil. A "loose" engine will use less fuel, due to less internal friction.
Daniel is right, but i would still complain to
the dealer. If you are burning that much now, think about how much you'll be burning when you hit 100K. It will not get better by itself, only worse! How knows, maybe you dealer will be sympathetic. Fat chance!
Burning oil
How many miles on your car?? I have the same 98 SE and mine drinks like 3/4 quart every 3 K miles, and I'm at 73 K miles on the odo now.
What Dan said is probably the casue, you may want to switch to a thicker oil, like 10W30 if you're using 5W30 already.
Re: Burning oil
I think I'd rather pay the extra money to add the additional
oil, than go with a 10W30. But i guess that depends on the climate/temperature where you live. In the Northeast, 5W30, is far superior to 10W30 for Winter driving. If flows better during the initial start.
Re: Burning oil
... ... you may want to switch to a thicker oil, like 10W30 if you're using 5W30 already.
MAXSE5SPD
Aug 23, 2015 12:06 PM
