Intake plenum gasket
I got a couple of intake plenum gaskets off of eBay for cheap, but now that I got em, they look like they're made out of paper or something. Is that what plenum gaskets made out of these days?
Yep...kinda like thick paper.
...might be e-bay fakes,does the box say "nisson" or nissan
heh,hah no ,but seriously you guys are you doing the performance intake spacers at the same time?
How cheap did you get them - they are $14 for both upper and lower from Courtesy Nissan.
to return a thought to you, when paper that thick gets wet, it expands. since the two pieces will be bolted down, it will only make the seal tighter. and i dont think it will fall apart just because of some oil...
wait, maybe this is just ignorance on my part, but why is it "wet and oily" in there to begin with?
Not that I'm Tampa, but off of CourtesyParts Beta site the upper gasket is $7 (SOHC), and the lower is $9(SOHC). The cheaper gasket you might see if for the DOHC engines
When I put my phenolic spacers in, I just used RTV for everything. I don't have any noticeable vacummings as I've tested with Intake cleaner around all the seals. Does anyone know if that's not a good idea?
Oh man, are YOU missing out! Man, spacers will boost up the power in your engine so much... dang. Sorry you missed out on the deal.
Spacers Thread
JK. I think Aaron still mfg'ing them.
Spacers Thread
Spacers Thread
Spacers Thread
clamp them together and torque the bolts to spec, you're gonna get RTV
squeezing out into the inner passages. I can't think of anything better to disrupt airflow. Stick with the original Nissan gaskets that have the built in rubberized surrounds. Cleaner, better, faster. IMHO...
Just because it works in a pinch doesn't mean it is the BEST solution. When you run a bead of RTV around the mating surfaces of those intake manifold parts (regardless of whether you are installing phenolic spacers),
Yes, (great fallback position) but-- I don't think that's possible when bolting down the "V" shaped upper plenum to the baseplate that attaches to the lower intake manefold. Granted, it's a "flat floor" arangement, but wiping away the excess isn't do-able. Therein lies my concern. Ahem...
Which engine are we talking about? Only place we used black RTV was between the dualduct and TB, and TB and UIM, and IACV and UIM on my VG... the VG kit didn't include a UIM spacer, due to the fact that it would have ended up making the kit less cost effective due to its complexity
passages. No?
Yeah? Look again! There's the lower intake manifold that bolts directly to the two cylinder heads mounted on the block, then, BETWEEN THE LOWER INTAKE MANIFOLD AND THE UPPER INTAKE PLENUM is a plate about 18 inches long with six eliptical holes-- one for each cylinder. It bolts down to the lower intake manifold with its own set of allen bolts, then the upper intake plenum bolts to it with ANOTHER SET of allen bolts. This last assembly once mated, does not allow any way in which to stick a finger into the passages created and smooth out any RTV squeezed into the
passages. No?
passages. No?
Hi, Matt! LOL-- I thought it was funny that he wanted to know if a set of VG gaskets were okay, and then thought it was an even better idea to throw in some RTV. (Where you can't wipe it away). Then didn't think there was an intermediate plate between the LIM and the UIP. THE HAVE TO GO TOGETHER SOMEHOW! Truth be told, I was jus' lookin' for an excuse to use that "slapper" emoticon! LOL
Say, My "package" ever show up?
In fact the ONLY time anyone on here mentioned RTV was for phenolic spacer installation, rather than using gaskets in addition to the spacers. So next time
before you
.That is all.
knight_yyz
Nov 1, 2015 01:34 PM
maxima297
Sep 30, 2015 03:32 PM
[/IMG]
[/IMG]
[/IMG]
