Need to find starter relay.
Turn key on and lights all come on as usual but when turn key to start I can't even hear the relay click. The starter does not engage or spin it is brand new only 2 weeks old. Battery tested at 13.2 volts. New ignition and put test light on wires coming of ignition and there is no kind of short. Also put a jumper wire in the neutral safety switch to test it to. My next step is this relay if I can find which one is which. Read in some old threads it was under the coolant resevoir but didn't see any there just on driverside fender.
Yes the alarm is still connected. Should I unhook it?
The only way you will have a relay box under your coolant reservoir would be if you had anti-lock brakes. Then your reservoir would be on the driver's side in exactly the same place that non anti-lock equiped cars is.
Most probably Relay, wire, rotten supply cable under batt tray... sometimes worn ign sw.
Close those possibilities out and test starter relay by giving it direct +12V from battery with a test wire.
http://www.cardomain.com/ride/748507/5
mikeg75
Nov 30, 2015 05:12 PM
pears
Sep 18, 2015 05:25 AM
