throttle bodies
Old Mar 2, 2008 | 09:06 AM
mastercoryd's Avatar
throttle bodies
hi i was wondering what size throttle body come in the vq30 and if there are other that you would recomend installing eater aftermarket or form a different car. and it possibe to have a throttle body that is to big??
thanks.
Old Mar 2, 2008 | 09:18 AM
Product_Of_Korea's Avatar
pathfinder tb
Old Mar 2, 2008 | 09:29 AM
Tatanko's Avatar
Bacon Lover
The only one commonly used is the Pathfinder throttlebody from previous gen. Pathfinders that had the 3.5 (not the 3.3 or 3.0). Theoretically you could put just about anything on with the proper adapter plate, but even the Pathfinder one will net you nothing but throttle response on an NA Maxima, especially with the stock intake manifold.
Old Mar 2, 2008 | 09:41 AM
thanks,so i would not get any hp if i got the pathfinder throttle body and got bigger injectors and got it tuned??also i was wondering about the q45 tb or is that to big??
Old Mar 2, 2008 | 12:19 PM
pmohr's Avatar
No more Maximas...
Why would you want a 90mm TB? Especially if you're staying NA.
http://forums.maxima.org/showthread.php?t=282056
http://forums.maxima.org/showthread.php?t=394508
http://forums.maxima.org/showthread.php?t=404001
BTW: http://forums.maxima.org/showthread.php?t=547220
Old Mar 2, 2008 | 12:24 PM
Tatanko's Avatar
Bacon Lover
Nope. Also, the injectors that come stock are way more than you'll ever need for any NA setup.
Our stock throttlebody: ~62mm (outlet)
Pathfinder 3.5: 70mm
Q45: 90mm
Old Mar 3, 2008 | 04:45 PM
RacerX1320's Avatar
TB and spacer?
What if someone ran a 3.5 path tb on a vq30 and then also ran a th spacer? Would that plus tunning add a few ponies? Or am I beating a dead horse now?
Old Mar 3, 2008 | 05:12 PM
MOHFpro90's Avatar
No, you will gain nothing with a Pathfinder throttle body, spacer kit or not.
Old Mar 3, 2008 | 06:01 PM
Tatanko's Avatar
Bacon Lover
I'm not sure if you know this or not, but PF throttlebodies are also quite expensive. Hefty fee for no gains.
Old Mar 3, 2008 | 07:37 PM
Pyromaniac1050's Avatar
its definitely possible too have too big of a TB. I used to have a 97 tbird with the 4.6 litre that I put a 70mm TB on, and I lost a good bit of my of bottom end power. and gained a little top end. with a smaller engine like the 3.0, stock would be best unless its boosted. 70mm is WAY too big for a 3 litre. an engine will only use as much air as it needs. a smaller opening speeds up air flow, too big and it slows down
Old Mar 3, 2008 | 07:40 PM
pmohr's Avatar
No more Maximas...
Are you trying to directly link displacement and cylinder head flow?
Old Mar 3, 2008 | 08:03 PM
what? no im not im sayin that. a 3.0 like that in the max, does not use as much air flow as a 70mm TB would allow. at least not in basically stock trim. maybe if you did some p&p, then it would be beneficial.
Old Mar 3, 2008 | 08:04 PM
do some port matching and then you might see some gains
Old Mar 3, 2008 | 09:28 PM
ajcool2's Avatar
If your looking for hp get a VI.
Old Mar 3, 2008 | 10:04 PM
Tatanko's Avatar
Bacon Lover
And these days, it's getting to be nearly as cheap as what a Pathfinder throttlebody + an adapter plate would cost.
Old Mar 4, 2008 | 01:02 AM
Old Mar 4, 2008 | 06:30 AM
NmexMAX's Avatar
dot dot dot ...
Cliffs:
Look elsewhere for performance.
Old Mar 4, 2008 | 09:20 AM
Tatanko's Avatar
Bacon Lover
Originally Posted by lock0002
I hope you're agreeing with me and not laughing at me
Old Mar 4, 2008 | 10:03 AM
black_maxed95's Avatar
hes agreeing with a smirk cause he just got his 00vi for a good price.
Old Apr 2, 2008 | 07:29 PM
neutronbob's Avatar
Nice wheels
Old Apr 2, 2008 | 07:30 PM
neutronbob's Avatar
Originally Posted by NmexMAX
Cliffs:
Those rims are the bomb.
REDinLV
Aug 15, 2024 12:30 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
