Question regarding tire rotation pattern??
Old Mar 16, 2008 | 08:48 PM
steven88's Avatar
Need A Light?
http://www.tirerack.com/tires/tirete....jsp?techid=43
I recently read this article on tire rotation on tire rack...my question is, is there any difference between the A rotation pattern and C pattern pictured in the article? It says A is primarily used for FWD and C is for RWD/AWD cars
It looks to me they are the same thing? Or am I missing something? My tires are NOT directional btw
Old Mar 16, 2008 | 10:17 PM
MrDicks95SE's Avatar
Offset Is Everything.
hmm the pattern is just reveresed. interesting. my consensus goes as is: fwd cars mainly use the front tires to drive the car so that is why it is moved to the rear and crossed after every rotation where as the RWD/AWD drive tires are moved to the front then crossed each rotation. the only difference is the drive tires are moved to the non drive side. with AWD, with the amount of squat from acceleration, the rears take most of the traction and would mimic the RWD rotation pattern? i dunno. thats my take.
Old Mar 17, 2008 | 08:34 PM
irish44j's Avatar
retired moderator
it also depends on if your tires are directional - if they are, then you can't rotate side-to-side or "X" pattern - only front and back.
Old Mar 17, 2008 | 09:23 PM
steven88's Avatar
Need A Light?
understood...do you know the difference between the A & C patterns though?
Old Mar 17, 2008 | 10:39 PM
its a reversal of pattern due to the fact that its FWD compared with RWD. just think about the drive tires and where those go. essentially they are the same, just reversed.
front drive tires shift to the back.
rear drive tires shift to the front.
easy as that.
MR2 T'd
Jul 9, 2021 05:06 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
