Hit a pothole, now shakes
Old Mar 19, 2008 | 06:51 AM
Jimothy12's Avatar
I was driving along and here comes a huge pot hole. I had a car on my left, curb on the right, and a car on my ***. I had no choice but to hit it. And boy did I! There is no visable damange. But when I drive over 50 mph the left front wheel (the one that hit the hole) starts to shake. Kinda like the wheel is off balanced.
What do you recommend? FYI: I plan on getting a new car within the next 6 months but need it to last until then. The cheapest fixed would be best.
Thanks!!
Old Mar 19, 2008 | 07:01 AM
LeVeL's Avatar
Wheel weight could have gotten messed up... maybe even developed a tire bubble. Take it to a shop and get an allignment and ask em to take a look at that tire and wheel weight.
Old Mar 19, 2008 | 07:16 AM
ROCKART's Avatar
wants an I35
you also could have bent the rim
i did this with a volvo hitting a pothole in nyc. the thing was like 2 feet deep.
a couple of weeks later this woman broke her leg stepping into it in the rain and sued the city for 15 million......
Old Mar 19, 2008 | 07:23 AM
maximase86's Avatar
I love lamp.
Have the wheels re-balanced. That's probably about the easiest way to fix it...but potentially you could of bent the wheel. Balancing can only help so much when you bend rims.
S
Old Mar 19, 2008 | 07:28 AM
Crusher103's Avatar
u notices any noises like a knocking, if so u might want to get that strut mount changed, its not that much so dont freak out it cost me $80 to get one of mine changed
Old Mar 19, 2008 | 07:32 AM
Jimothy12's Avatar
The tire presure was low so it could be a bent rim. I made an appointment at the local shop for Saturday to have them check it out. The strut is about shot anyway so it would surprise me if thats done now. I'll see what the shop recommends
Old Mar 19, 2008 | 10:00 AM
MrDicks95SE's Avatar
Offset Is Everything.
check the wheel and get an alignment.
Old Mar 19, 2008 | 10:33 PM
GoldMax96's Avatar
i would guess you most likely bent the rim since you hit it so hard
Old Mar 19, 2008 | 10:41 PM
Snypa's Avatar
sounds easily like a bent rim.could also be bent axles or sumin more serious.get it checked out.
Old Mar 20, 2008 | 07:24 AM
maximase86's Avatar
I love lamp.
Can you really bend an axle on a pothole? That seems really unlikely considering you have cv joints at 2 points, the joints would likely move before you could bend an axle. I can maybe see this is your axles are old and the cv joints were on thier way out and sticking or something or somehow bend the joint beyond it's ability...which would really be prevented by the spring/strut travel anyway.
S
Old Mar 20, 2008 | 07:37 AM
Crusher103's Avatar
lol if u bent a axle by hitting a pothole Ur car should automatically be considered maxima of the month
Old Mar 20, 2008 | 09:19 AM
Snypa's Avatar
^^^LOL....ohh,ok man.bent rim it is then.
Old Mar 20, 2008 | 12:37 PM
QNO_A32's Avatar
befpre you bring it to the shop just rotate the driver side in your driveway.should make a difference.an alignment will not help you in any way.put the driver front on driver rear and driver rear on the front.should solve your problem......
Old Mar 20, 2008 | 02:39 PM
titanbk's Avatar
x2 if you are looking for the cheapest fix possible its worth a shot. Just make sure there is no bubble in the tire, blowouts are nothing to play around with.
Old Mar 20, 2008 | 06:15 PM
and what are you going to do with that bad wheel/tire? leave it on there?? bad suggestion IMO. the problem will still persist no matter how you look at it whether it be an alignment problem or a bent, unbalanced wheel. jeez what kind of suggestions are you people giving... terrible.
get it done once, get it done right. take it to a shop and have them check it out to make sure the wheel is straight and balanced. It shouldnt cost you anything to have them look at it. if the wheel is straight and balanced and you are still having issues, have an alignment done. usually just hitting a curb at a good enough speed will knock your alignment off. as far as bent axles, i VERY HIGHLY doubt it.
Old Mar 20, 2008 | 07:42 PM
titanbk's Avatar
Thanks!!
I do believe that rotateing the tires would possibley diagnose the problem saving him in charges from the shop. He asked for the cheapest way to get him another 6 months.
Old Mar 20, 2008 | 10:00 PM
and hows that? id really like to know. rotating the wheels/tires is NOT going to solve anything. that particular wheel is still going to be f*cked up (given that his wheel is bent) no matter where you put it and how you look at it. like i stated before, there is NO cheap way to dealing with this without going to a professional and having them diagnose the problem.
if you sell the car, its not going to sell all too well with a problem like that. driving like that for 6 more months... well its your fault if your tire blows off or wheel cracks into pieces (worst that can happen and you crash).
Old Mar 20, 2008 | 10:14 PM
vqmaxman's Avatar
I would be thankful that the pothole was not deep enough or It could of bent your frame from where your strut mounts (top of the frame) and a bad lower control arm and you would of been just sitting there waiting for some help. I would check the tire out for lumps and some dents and I would check out the rims also. I would check for suspension damage anything looking bent or crooked. I would definitly do the alignment for the car Good luck.
Old Mar 21, 2008 | 10:06 AM
QNO_A32's Avatar
hey man ,whats your problem you e thug.he asked for THE CHEAPEST WAY TO FIX IT. maybe you should read the first post ****95.balancing that wheel will not help it that much.putting it on the back will help 10X more than simply balancing it and leaving on the front. actually right rear will help the most if its not rotational. any ont that knows anything about automobiles will tell you that you effing newbie! IF YOU CANT HELP THE POST DONT POSE THAN.WHATS THE PROBLEM. to op just rotate the passenger side you will thank me.
Old Mar 21, 2008 | 12:35 PM
ethug... . thats not fixing it. thats putting it aside and ignoring it. and its NOT going to cost that much just to get the wheel checked and balanced. if thats not cheap enough for you, well then youre just a broke cheapass.
you forget, the wheel will STILL be messed up. (given that it is the problem)
I'm the 'effing newbie' huh. well i thank you for that HELPFUL post. The smart thing to do would be to get it properly diagnosed and fixed. 6 months driving like that is a long time especially if there is something wrong with the wheel or suspension. if you read my post you would see that getting it diagnosed and fixed and doing it right IS my suggestion. so why dont you get YOUR facts straight 'you effing newbie.'
Old Mar 21, 2008 | 12:58 PM
QNO_A32's Avatar
yeah my bad for the *****ing lol but his rim is bent from hitting the pothole.also when he hit it, it probably whacked his toe out a little bit. have it spun and if its salvageable, balance and put on vehicle.than do the alignment. for both those are probably around $80 bucks or so.is the tire/wheel holding air? worst comes to worst, you need a new wheel and tire plus alignment. but definatly try and rotate that one to the back first. and yes mr****95 the problem will still be there and thats not the right thing to do but he seems like a dumb cheapass
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
dshinn
Sep 26, 2015 08:07 PM
