Courtesy Front Strut Tower Brace
Old Oct 30, 2001 | 05:56 PM
wombat
I'm interested in getting a Courtesy Nissan Front Strut Tower Brace for my 2001 GXE Maxima, but one website says I need to saw off something to make it fit. Is this true? I don't want to void my warranty, nor do I want to saw anything on my car.
Please email me with recommendations or information.
Thanks!
Mike
michaeljrizzo@yahoo.com
Old Oct 30, 2001 | 06:01 PM
2maxguy's Avatar
Just recently installed it myself. It's about a 10-15 minute job and nothing needs sawing off. Bar clears everything on engine, however I think it touches hood liner-no big deal.
Old Oct 30, 2001 | 06:05 PM
2maxguy's Avatar
Just recently installed it myself. It's about a 10-15 minute job and nothing needs sawing off. Bar clears everything on engine, however I think it touches hood liner-no big deal. This is an easy mod, I give it 1 wrench!
Old Oct 30, 2001 | 06:08 PM
AznWontonboy's Avatar
you've had way too many maximas..
Old Oct 30, 2001 | 06:11 PM
2maxguy's Avatar
How many is too many?
Old Oct 30, 2001 | 09:22 PM
Raf2kMax's Avatar
courtesy nissan has it for like $90. if nissan themselves are sellin it..it HAS to fit right for the car i guess. i think im gonna save the money and just go for these soon.
Old Oct 31, 2001 | 01:16 AM
woosh's Avatar
Re: Courtesy Front Strut Tower Brace
Thanks!
Mike
What I observe:
-The front end is stiffer so it takes bumps/potholes a little harder
-a pothole on one side seems to be absorbed across the whole front(not bad though)
-the car handles corners really sweet
-able to take corners at higher speeds
Old Oct 31, 2001 | 03:32 AM
MaDxKiLLa's Avatar
wow everyone has 2002 HIDS nowadays
Old Oct 31, 2001 | 04:21 AM
DeaZaL's Avatar
I was going to get them when they first came out.. I said, "Nahh they are so cheap now i'll wait till after winter and they will be real cheap.. argggg
Old Oct 31, 2001 | 06:49 AM
jnovember's Avatar
Just installed the Courtesy FSTB this weekend. Took 15 minutes. Nothing to "saw off". Mine fits perfectly and doesn't even hit the hood liner (as other's have reported). Makes a huge difference in handling, as has been mentioned in detail in other posts. I highly recommend this mod!!!
Old Oct 31, 2001 | 07:08 AM
alias
where do you get the 'Courtesy FSTB'??
Old Oct 31, 2001 | 07:11 AM
MichaelAE's Avatar
Thanks!
Mike
Its "bolt on." No modification needed, no sawing, nothing at all which requires thought other than using a torque wrench to screw the strut tower bolts back on to 35 ft/lbs.
Old Oct 31, 2001 | 04:33 PM
JUDE's Avatar
I'm not mechanically inclined. When you say to torque it to 35lbs/ft how do you know that its at 35?
Old Oct 31, 2001 | 04:39 PM
MichaelAE's Avatar
http://www.courtesyparts.com
Old Oct 31, 2001 | 04:41 PM
MichaelAE's Avatar
To be accurate, you need to have a "torque wrench" which is tuned (adjustable) to release pressure at a specific torque setting.
Some members of the board have chosen to guess. I, myself, purchased a torque wrench at Home Depot for around $50.
http://www.homedepot.com and search on "torque wrench"
Old Oct 31, 2001 | 04:42 PM
HulaMAX's Avatar
You take a 70lb kid (35lbs per foot) and have him torque it for you...
j/k!
The only way you can torque anything correctly is with a torque wrench...you can pick one up at your local hardware store.
Old Oct 31, 2001 | 04:48 PM
MichaelAE's Avatar
j/k!
To add to HulaMAX's post and my previous one...I paid $50, like I said, but there was one less "nice" version for about $30. Good investment if you a Tim Allen type.
Old Oct 31, 2001 | 05:06 PM
soundmike's Avatar
Very sound, Mike
Michael,
I have a question. There were two types on the Homedepot site. 3/8" and 1/2"
Which one did you get?
Also, what would be a good place to "park your car in a level area"?
Thanks.
Old Oct 31, 2001 | 05:11 PM
MichaelAE's Avatar
Originally posted by soundmike
Michael,
Thanks.
I purchased the 3/8" because it is more granular. The 3/8" is designed for torques from 10 ft/lbs - 100 ft/lbs. The 1/2" is design for 25 ft/lbs - 250 ft/lbs. Don't anticipate needing the heavier duty one, so I opted for the one with smaller increments. For the FSTB, both can be set to 35 ft/lbs, so you can get either.
I did the installation in my garage...which is as level as it gets. I think that, assuming you do not have a level area near you like a garage...find a parking lot to do it in...it really doesn't take that long.
Old Oct 31, 2001 | 05:21 PM
soundmike's Avatar
Very sound, Mike
Sounds good. Thanks for the info!
I'm probably gonna get the Courtesy FSTB as well given it's much cheaper and i don't really see anyone complaining about it. I just hope it fits the 02 bay.
Which one did you get? And, i know this is a frequent question but, do you really feel the difference even in normal day-day traffic or is it only when you push the max to it's limits?
Thanks again!
- Mike
Old Oct 31, 2001 | 06:25 PM
MichaelAE's Avatar
Thanks again!
- Mike
I got the Courtesy...and yes, I feel the difference...however, I do have one question?
What's normal day-to-day driving???
Old Oct 31, 2001 | 07:00 PM
JUDE's Avatar
Thanks for your help Michael. I'll pick up a cheap one from Home Depot.
Old Nov 2, 2001 | 12:18 AM
the paragon's Avatar
HI Mike
there is a 3/8" Beam torque wrench for $18.97, 3/8" Click style torque wrench 10-100lbs
and another 3/8" Click style torque wrench 25-250lbs for $53.97
which one did you buy?
thanks
Old Nov 2, 2001 | 07:53 AM
MichaelAE's Avatar
Originally posted by TaiwanMaxima
HI Mike
thanks
I bought the 3/8" click-style 10-100 lbs. For this application, it really doesn't matter which one you buy...all three will cover a 35 ft/lbs adjustment.
I chose the click-style because those are more sturdy than the beam torque wrench with the dial/needle gauge. It would also appear to be easier to ensure accuracy. I chose the 10-100 lbs since I saw the potential for granular applications between 10-100 lbs in future projects, unrelated to my Maxima, more likely than 25-250 lbs.
Old Nov 2, 2001 | 08:07 AM
MichaelAE's Avatar
One more thing...
With the Courtesy, at least, if you install the bolts facing the windshield, you will not be able to get the wrench in place to tighten the top bolt on the strut tower...so you should install the bolts facing towards the front of the car.
Old Nov 2, 2001 | 02:54 PM
Great@! THanks for the feedback.
Old Nov 8, 2001 | 10:46 PM
hey mike
kinda having trouble tightening the bolt on the driver's side. there seems to be that black brace blocking the way. is there anyway i can tighten the bolt?
Old Nov 9, 2001 | 10:30 AM
MichaelAE's Avatar
hey mike
I'm not able to go down and take a look at my car right this second...can you explain what "black brace" you are referring to? I do not remember having any issues with the bolts being blocked.
Old Nov 9, 2001 | 10:33 AM
punkdork's Avatar
Probably a bracket for the airbox. Just remove it temporarily.
Old Nov 9, 2001 | 02:26 PM
Yea, its the airbox. So u say remove it temporarily? will i mess up any sensors in the process? just wondering
thanks
Old Nov 9, 2001 | 02:31 PM
Greg's2kGLE's Avatar
You only have to cut a braket if you happen to get the early production ones which were for the 4th gens but fit the 5th gens by cutting about 1/3" off a bracket on the driver's side. If you buy it new from Courtsey, you will probably get one that fits perfectly....take off the bolts, put the bar on, tighten the bolts. Oh and make sure you do the install on a flat surface...
Old Nov 9, 2001 | 02:41 PM
I purchased the FSTB from courtesy which fits perfectly. But the fact is that i can't tighten the main bolt on the brace (Driver's side) because of the airbox bracket in the way. Is there someway to tighten it?
Old Nov 9, 2001 | 02:47 PM
punkdork's Avatar
thanks
Is it a little bar that is connected to the strut tower by like two bolts and it connects to the airbox? If so, that's what I was talking about and no sensors will be harmed in its temporary removal.
If that's not it, do you have a digital camera you could take a pick with?
Old Nov 9, 2001 | 05:57 PM
yep, its the brace with 2 bolts that connect to the airbox. so removing that temporarily is alright?
thanks
Old Nov 9, 2001 | 06:31 PM
punkdork's Avatar
thanks
Yeah you're totally fine removing that brace
Old Nov 9, 2001 | 06:33 PM
MichaelAE's Avatar
General rule of working on cars...if it comes off with a wrench...its okay to take off...if it requires jacks or power tools...ask first.
sascuderi's Avatar
waiting
Just ordered my FTSB from Courtsey tonight. Using ground UPS from Texas to NJ. Wonder how long it will take to get here???
Old Nov 9, 2001 | 07:20 PM
2maxguy's Avatar
Re: waiting
It took almost 1 week to the day to receive my FSTB from Courtesy to NJ. The rear sway bar really helped complete the package. I went with the Stillen over the Addco. Too many bad posts on the Addco, the Stillen cost $234+ shipping from GR Racing in Pa (www.eatricezone.com).
Old Nov 9, 2001 | 07:47 PM
Its not a bad thing. But damnnnnnn thats a lot.
Old Nov 9, 2001 | 07:55 PM
My FSTB took about 2 weeks, cause i ordered other things that required UPS shipping including the valence grill.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
