No power to H/U
Old Apr 17, 2008 | 06:17 PM
kauaiwyatt's Avatar
No power to H/U
hi guys, today i installed a Pioneer DEH-1900MP, and it won't power on. I installed the ground to the stock harness ground (12V-) instead of to bare metal on the car.
Shouldn't it still power on? I checked all the wiring, & it matches up. What else could it be besides the ground?
thx
Old Apr 17, 2008 | 06:41 PM
imported_Jay_5's Avatar
what year is your Max... 3rd 4th and my 5th gen dont have ground at the radio harness thats why you ground it to the chassis... try it see if it helps...
Old Apr 17, 2008 | 07:22 PM
kauaiwyatt's Avatar
hey, it's a 5th Gen. thx for the response. i will get a multimeter & test the 12V and ground.
Old Apr 17, 2008 | 08:45 PM
abomb1987's Avatar
have you checked fuses?
Old Apr 17, 2008 | 09:03 PM
kauaiwyatt's Avatar
yes, i've checked the fuses. I remember doing the same install in a 4th Gen, & I used the ground in the factory harness. It worked fine.
Old Apr 18, 2008 | 02:55 PM
kauaiwyatt's Avatar
Hey, you guys were right! It was the 15A "Audio" fuse under the hood. I thought it would have been a fuse under the steering wheel. I guess the fuse popped when the thieves got my last H/U. Thx again for the advice. Oh yeah, the ground in the factory harness works fine.
Old Apr 19, 2008 | 04:49 PM
Pearl96Max's Avatar
I tend to get a bit irritable
The ground in the factory harness is not actually working fine. Your grounding through either the chassis or the antenna (floating). I would suggest re grounding directly to the chassis rather than the harness.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
