Blue GXE gauges?
Blue GXE gauges?
I have a 92 GXE and the spedometer broke so i have to put in a new one anyway...is there any way to get the gauges from what they are now (green) to blue? and if so where can i buy this?
if you have had your cluster out before and didn't find it hard, then no. If you haven't, then just keep track of all the screws and you'll be fine. Remove lower dash panel, then the one where the cruise/dimmer/defrost switches are, then the one where the radio and climate control stuff are, then the big black one with 3 of the 4 vents, then the cluster. unplug stuff as you go but don't worry, each plug is unique to its switch/clock/whatever so you can't mess it up. Pull the cluster out and the large burgundy light holders are the backlighting.
Alright im going to have to try this later, ill try and see how i do just taking apart the dash before i bother buying the lights...Thanks again for the help.
blue 194s are what you're looking for.
i couldn't tell you, since the only time i had blue was in SE gauges. even those though are a bit cyan-ish. so it may be pretty much straight jungle green, or it may be moreso blue. You'll just have to wait and see. It is possible that purple and green will make blue though. Just like red and green make amber. I'd suggest getting one pair of blue, and one pair of purple, test to see which is bluer behind the green, then go back and get 2 more of the one that works best.
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
