Horn won't shut up
Old May 11, 2008 | 08:31 PM
Graem's Avatar
Horn won't shut up
So I went to wash my car yesterday and i pulled out of the car wash and the horn started going crazy. It would not stop buzzing and had nothing to do with the stearing wheel. I found two plugs on the horn and disconnected them but what a PITA. Who esle has had this problem?
Old May 11, 2008 | 08:38 PM
MOHFpro90's Avatar
Just a short, water probably crossed the contacts.
Old May 12, 2008 | 01:11 PM
vilmaxima's Avatar
^^, check your wires.
Old May 12, 2008 | 01:12 PM
S1cTech's Avatar
"yah, is obv the wires.. Just pull the fuse for now, until its fixed... Man that must of been embarrassing coming out of the car wash... haha...
Old May 12, 2008 | 04:30 PM
Graem's Avatar
ok, today when i was driving to work i figured out that whatever happend cut out my cruise as well. Should i just get it wet and try to reverse what happened or what. Its all dry under there now and it still won't shut up.
Does anyone know what fuse controls the horn, i found three under the hood labled horn but i don't know what one to pull.
Old May 12, 2008 | 04:31 PM
Graem's Avatar
yeah, it was very embarrasing sitting there with a car thats going crazy
Old May 12, 2008 | 04:50 PM
Nopike's Avatar
It's fuse # 64 (10AMP) not sure it's under dash or under hood fuse box. You can also pull out the horn relay located in the relay box near the battery. The relay or trouble in the relay box could be causing your problem.
Pulling either of these will definitely stop your horn.
Old May 12, 2008 | 05:26 PM
MOHFpro90's Avatar
If it is dry, and still makes noise, I am going to say it is you relay. Check the box by the windshield wiper fluid.
Old May 12, 2008 | 09:05 PM
maxgtr2000's Avatar
KH3 by popular demand
Mine would go off on it's own, turns out the steering wheel portion caused some sort of problem, I would have to press the horn to get it to stop. It only did this about 3 times ever.
Old May 12, 2008 | 09:10 PM
Feldman's Avatar
horn and cruise cont. are on the same fuse if that little tidbit of information helps...
Old May 15, 2008 | 09:30 AM
Graem's Avatar
I kinda figured that when both went out at the same time. How many relays are there for the horn and cruise and how do you check them to see if they are ok. I think that somehow the ground wire is being grounded before it come back to the stearing wheel but how would this happen and how can i fix it.
DJLAX152
May 4, 2021 11:46 AM
hayne
Oct 5, 2015 11:53 AM
Sep 27, 2015 08:37 AM
EdRomo86
Sep 12, 2015 07:49 PM
