Wheel spacers: One design better than other?
Old May 15, 2008 | 08:20 AM
n3985's Avatar
大陆弟弟
While shopping for wheel spacers, I noticed two designs:
1. Eibach/H&R/Ichiba - gives you longer studs
2. Generic spacers with built-in studs
#2 will obv be easier to install, directly to the hub as opposed to installing new studs.
But is one design better than the other? Thanks
Old May 15, 2008 | 08:53 AM
BLACKonBLACK98's Avatar
Former Vendor
those companies also offer the type with built in studs, but extended studs is the way to go unless you need pcd conversion. also imortant is the material. make sure they are cnc machined aluminum and not cast anything.
Old May 15, 2008 | 09:01 AM
MrDicks95SE's Avatar
Offset Is Everything.
I had 25mm H&R's with built in studs. worked fine. i dont expect anything less than perfect spacers from H&R and Eibach.
Old May 15, 2008 | 09:09 AM
ROCKART's Avatar
wants an I35
where are you looking for these?
other than ebay, i dont see any vendors for them
Old May 15, 2008 | 09:13 AM
n3985's Avatar
大陆弟弟
Ya was searching for Ichiba spacers on eBay and found those.
http://cgi.ebay.com/20MM-WHEEL-SPACE...QQcmdZViewItem
Old May 15, 2008 | 10:04 AM
AuTo_MaX_95 sells H&R spacers, PM him for pricing.
where you can also buy:
www.ichibausa.com
www.optauto.com
www.optionimports.com
Old May 15, 2008 | 10:27 AM
n3985's Avatar
大陆弟弟
Thanks for the links, although I know it's better to buy a product from a reputable company i.e. H&R or Eibach, the easier install on the eBay spacers is really tempting
James92SE
142
Jan 2, 2024 09:23 AM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
240tomax
Sep 13, 2015 03:28 PM
dcam0326
Sep 8, 2015 11:02 PM
