Wheel spacers: One design better than other?
While shopping for wheel spacers, I noticed two designs:
1. Eibach/H&R/Ichiba - gives you longer studs
2. Generic spacers with built-in studs
#2 will obv be easier to install, directly to the hub as opposed to installing new studs.
But is one design better than the other? Thanks
those companies also offer the type with built in studs, but extended studs is the way to go unless you need pcd conversion. also imortant is the material. make sure they are cnc machined aluminum and not cast anything.
Ya was searching for Ichiba spacers on eBay and found those.
http://cgi.ebay.com/20MM-WHEEL-SPACE...QQcmdZViewItem
AuTo_MaX_95 sells H&R spacers, PM him for pricing.
where you can also buy:
www.ichibausa.com
www.optauto.com
www.optionimports.com
www.ichibausa.com
www.optauto.com
James92SE
142
01-02-2024 09:23 AM
