HOW TO: Custom A32 Large Bore MAF
Old May 15, 2008 | 08:09 PM
MOHFpro90's Avatar
I will not be responsible for any thing that happens to you, your car, or any other piece of your property that occurs before, during or after making, assembling, testing and/or using this MAF.
This is a short but sweet write up I made for you peeps wanting your own large bore MAF. I have yet to test it, I have no Air/Fuel controller.
Parts:
Your new MAF tube
Your current(or spare) MAF housing
Saw zaw/hack saw
Drill and/or router
The housing:
Inner Diameter: 3 3/8"
Outer Diameter: 3 1/2"
Length: 6"
Using the STOCK sensor.
So, lets get on with it.
How To:
1. Use a razor or exacto knife(#11 blade works well) to remove the seal around the edge of the cap. The seal is highlighted in blue on diagram 1.
2. Use the combination of a small flat head screw driver and your exacto knife to pry open the cap. You can see from the picture, I accidentally broke the wall of mine, this is no big deal as once I get it running, I am going to seal it back off with liquid gasket.
3. Remove the four outer screws on the plug itself. Be careful not to strip them, they arent easy. These are highlighted in red on diagram 1. DO NOT PULL ON THE PLUG!
4. Next, there will be a brass protector just under the plastic cap you just removed. It comes straight out, but may need some prying.
5. Here comes the harder part. You need to disconnect the main harness from the inside circuitry. The three contacts are highlighted in red in diagram 2. You have two options here:
a. The easy/fast yet risky way: Use a small flathead screw driver to break the 3 contacts to the plug from the leads off of the main circuit board. Just pry. They will come off. But too much stress and they will break. If they do, you will need to solder a new connection in.
b. The proper way: Simply use a soldering iron to heat up the solder joint, while using a small flathead to pry at the same time. No breaking, no risk.
6. Remove the three screws in the main circuit board. These are highlighted in orange in diagram 2.
7. Use a medium flathead to CAREFULLY! pry the main circuit board out of the housing. There is a rubber seal, and what I believe is locktite holding it in. Stick the screwdriver through the hole where the sensor plug came out of.
8. Set everything off to the side. Take your empty MAF housing and use a hack saw, saw zaw or other appropriate tool to cut plastic to make your cuts. I just did mine flush with the walls of the housing(seen is diagram 1). I then cut the sensor post from the inside of the housing. (yellow highlight, seen in diagram 3)
9. For me, this was the longest part. I am a perfectionist. What happens is, since the diameter of the black MAF tube was smaller than the large one, this means that the sensor housing will not sit nice and flush with your new tube. So I used a bench grinder to get the right shape. You can see where I grinding out, diagram 1, highlighted in pink.
10. Almost there, now just mark your hole on your new housing. I use an aluminum housing, PVC can cause harmful fumes, not to mention it doesnt resist heat well. I used a drill bit and a router to cut my hole. I just kept test fitting until it fit nicely.
11. Last step. Use some super glue to secure the sensor housing to the new tube. Once it is dry, use liquid gasket, or similar, to make an appropriate seal around the edge.
Finally, just reassemble everything with caution, and don't forget to re-solder the plug so it will work!
The Final Product:
Old May 15, 2008 | 08:10 PM
DrunkieTheBear's Avatar
Turbo'd Saab
Thats my pipe, so i deserve some credit, cause it was my money that bought it.
Nice job dude. It should be noted no one should do this with out proper tuning. He is not responsible if you go lean and you blow your engine. So tune your car.
Old May 15, 2008 | 08:12 PM
Snypa's Avatar
LOL^^....Great Job MOH,looks pretty good. Nice work.
Old May 15, 2008 | 08:43 PM
Product_Of_Korea's Avatar
oh i will
Old May 15, 2008 | 08:51 PM
black_maxed95's Avatar
no dyno no care...lol jk. good write up man. now all the noobs will be blowing up their engines
Old May 15, 2008 | 09:11 PM
Turbo'd Saab
The sad part is your probably right :sad:
Old May 15, 2008 | 09:41 PM
MOHFpro90's Avatar
I do plan on doing one sometime soon, but most of my attention is on the torn down vq30 in storage right now.
Thanks for the compliments guys.
Old May 15, 2008 | 10:16 PM
bigpulve+'s Avatar
Nice write up and finished product kyle....now get what needs to be done done...
Old May 15, 2008 | 10:28 PM
HomerMAC's Avatar
Donating i30 Owner
SOON as i saw this.. I wanted to make one... then I thought this mod would become a lot more expensive cause i would now be FORCED to get Greddy EU...
Great pictures by the way... I mean I will remember how you made this no matter how long it takes me to get to the point where I need to do this...
Old May 15, 2008 | 10:32 PM
bigpulve+'s Avatar
oh and kyle you should donate one of these to me and let me tune with it and the amazing EU harness youre making....
Old May 15, 2008 | 10:44 PM
MaximaSpd85's Avatar
so this is probably not too safe without tuning? sorry, dont know much about MAF and its readings, ....
also, is the MAf screen just no longer usable? not really needed? wish we could re-use it? like i said...
Old May 15, 2008 | 10:51 PM
gtr_rider's Avatar
192.168.1.1
you could always cover each end of the new pipe with a mesh
Old May 15, 2008 | 11:18 PM
MOHFpro90's Avatar
Bigpulve, dont worry, I am. Oh, and I do have a spare piece of pipe, I just need to get a spare MAF and Ill make you one. As long as Dave doesnt want the piece of pipe back.
HomerMac, I have yet to know if its worth it, but it was sure as heck fun making it. Haha.
Maximaspeed85, yeah it would not run well(if run at all) without a tune. Far too lean.
And mesh is always an option, but not really needed. Your filter should filter it.
Old May 16, 2008 | 01:35 AM
maxgtr2000's Avatar
KH3 by popular demand
Sticky when it works.
Old May 16, 2008 | 06:54 AM
Flava_24/7's Avatar
Boosted Panda
Seems like overkill for an NA engine and also using the stock sensor.
Also, why would you use super glue to attach the plastic housing to the aluminum piping? Why not use something more durable such as JB Weld or etc.?
Old May 16, 2008 | 07:16 AM
just want to point out that the mesh is not for filtering. its to direct the airflow so it travels straight through the MAF and prevent it from being turbulent. A turbulent flow will give a slightly inaccurate reading. So the mesh is helpful to have but it is not completely needed as others have done this without meshes.
also note that there is a small blade on the sensor right before the resistor, that is also there to direct the air flow in a straight line before hitting the sensor.
heres a pic of what im talking about.
Old May 16, 2008 | 09:27 AM
khantalha+'s Avatar
good stuff... i am workin on my safc 2 and eu install right now!
Old May 16, 2008 | 09:41 AM
NmexMAX's Avatar
dot dot dot ...
just want to point out that the mesh is not for filtering. its to direct the airflow so it travels straight through the MAF and prevent it from being turbulent. [/IMG]
It's not like our MAF's are calibrated very well anyhow, we've all seen the near stock A32AFR curve, but I know and see your point.
Also, since this thing is about he same size as the LRMAF, looking at his design, one could easily (with enough time and detail, as the OP has represented here) do this w/ the LRMAF, which indeed has a honeycomb / mesh, etc you speak of.
BTW, this thing must be MASSIVE, (85mm ID), so be VERY careful, ESPECIALLY w/o any AFR control / monitoring.
Old May 16, 2008 | 11:14 AM
MOHFpro90's Avatar
JB weld doesnt hold well to smoother surfaces. The superglue holds very well, thats the least of my worries.
TallTom
57
Oct 14, 2025 05:16 PM
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
