5th gen mirrors install, need help with base
Searched, but didn't find anything useful.
I recently purchased an A33 Cefiro power folding mirrors (You can see the silver mirror in my sig). Why? Well, to be different, why else... And of course different I got. Now I need to manufacture a new mirror base. Has this been done before? What materials were used? Thanks!
I assume the mounting holes underneath the main housing are in a differen position/different amount? Have pics of the underside? Before I got my JDM Power Folders I completely disassembled my mirrors and if the mounting holes are the same (and the plug matches up) it should be swappable.
Is that a JDM mirror?
It's original Nissan. I will have to do some drilling in the door brackets to make some new holes which won't be the problem. The problem is insulating the thing so it doesn't leak inside the door panels (which I think it does at the moment). And of course there's the cosmetic look issue on the outside.
I'll take some pics in the lunchtime.
I meant the mounting holes on the swivel, not on the door itself. Maybe you can use the A32 mount with the A33 housing. FSM doesnt give a diagram and I deleted my Nissan fast so I cant get a pic of the armature.
seriously, why the infiniti badge? i30's put nissan in places to emulate a Cefiro, never heard of someone emulating an infiniti, especially with OEM maxima front end...roflcopter
Cause I got a really good deal on them and I never seen them so cheap ($120 with shipping to Canada)
Here is another problem you may run into. Not sure where you got yours from, but mine came straight from Japan which makes them almost completely non-functional. With the Right hand drive, I get to see the entire side of my car from the dirvers mirror and I get to see 3 lanes over from the passenger mirror. I havent taken the time to figure it out yet, but this weekend I'll see if it is the glass that needs to be switched back to USDM or the bracket inside. (Hoping it's the plastic bracket so I dont have to go get heated glass. Plus I think the JDM would give a wider viewing angle.)
Just curious, where in Canada?
Toronto, ON.
Doesn't seem like that's a problem with these mirrors. I can adjust it so the view is the same as it would be with USDM. They are from Japan though. I had to modify the US 5th gen mirror shells and glue them into the mirror.
Finkle
Sep 27, 2015 09:53 PM
You go the OEM switch right?
