Clear Tails Question
Old May 29, 2008 | 06:01 AM
josh662234's Avatar
I've searched and searched but can't find my answer. When installing the acrylic piece into the tail light. . . does it go into the actual housing or do you cut it to fit flush with the lens? It seems like it would be a PITA to fit it into the housing and make it stay. any advice?
Thanks in advance
Old May 29, 2008 | 10:51 AM
josh662234's Avatar
does any1 know what i mean?
Old May 29, 2008 | 12:59 PM
ptatohed's Avatar
Licensed to Spell
Why don't you be more clear (no pun intended)? What year taillights? What style taillights? Pictures?
Old May 29, 2008 | 02:21 PM
josh662234's Avatar
sorry i was at work and just tryin to get it out quick. I have a 97SE with stock tail lights. i'm taking the orange out of the bottom outer tail light. i peeled them apart like the DIY said. took out the orange reflector, and bought a sheet of clear acrylic plastic. I am wondering where to put the piece of acrylic plastic. do i cut it and place it into the light housing, or do i cut it and fit it right onto the inside of the actual lens? It seems like it would be easier to fit it to the lens and get it to stay.
Old May 30, 2008 | 11:12 AM
Digitized's Avatar
it should go where the "original" orange piece went...
Old May 30, 2008 | 05:55 PM
josh662234's Avatar
Thank You!! i thought i would never find out. Now is this held in with some clear silicone or just some super glue?
Old May 30, 2008 | 09:17 PM
roggeezy's Avatar
http://www.vqpower.com/v2/infusions/...?article_id=46
It says you wedge it in their.
Old Jun 3, 2008 | 09:31 AM
josh662234's Avatar
tried that. . . once i heat it and bend it. . . .it just falls out
Old Jun 4, 2008 | 11:47 AM
JNCoRacer's Avatar
Just the tip.
Once you put the acrylic in the lense and you put the light back together it will hold its shape like it should.
Old Jun 4, 2008 | 12:08 PM
ROCKART's Avatar
wants an I35
i litterally just held it (bent) in place while the RTV dried. its a ***** i know
took about 15 minutes before it stayed by itself.
Old Jun 4, 2008 | 12:43 PM
josh662234's Avatar
so ROCKART. . . u used some clear RTV?
Old Jun 4, 2008 | 12:45 PM
ROCKART's Avatar
wants an I35
yes, just on the ends (the short sides) and held it till it dried.
Old Jun 4, 2008 | 01:00 PM
MaximaSpd85's Avatar
cut yourself another shape that will wedge in there. you probably made your piece too small so that it has nothing to "wedge" onto. did you get understand that? i just wedged mine in there and it stayed, it was a slightly tight fit.
Old Jun 4, 2008 | 05:36 PM
josh662234's Avatar
i guess i'll make another template and see if i cant get it to fit real tight. i'm cutting it with a soldering iron . . . is it a lot easier with a dremel??
Old Jun 5, 2008 | 08:16 AM
Graem's Avatar
use a utility knife, I did mine last weekend and just traced the orange lense onto the acrylic sheet and then cut with a staight edge and utility knife and the cut or broke it along the skored line. Just put the cut piece where it belongs on the lense, kinda wedge it in there and then when you put the housing back on it will all be held in place.
ever tried usin google?
Old Jun 5, 2008 | 08:19 AM
ROCKART's Avatar
wants an I35
that utility knife didnt do **** for me
whenever i would press hard into the acrylic, it would spiderweb; and whenever i tried to score a line to snap off, it would just crack along some random line.
maybe acrylic in your part of America is better than mine?
either way, using an electric rotary tool is the EASIEST way.
Old Jun 5, 2008 | 09:29 AM
Ruthless's Avatar
i didnt use glue or anything. That was a ***** tho... Stressful because lots of patients is needed
doctorpullit
Apr 23, 2017 05:35 AM
jchronis2552
Sep 21, 2015 05:52 AM
pears
Sep 18, 2015 05:25 AM
Steven Orozco
Sep 12, 2015 10:41 PM
Johnny9595
Sep 3, 2015 05:18 AM
