Do I need factory camber settings with this drop?
I just installed D2 coilovers and I am in need of a new alignment. I just changed my axles also. The G35 wheels I have on now only work with the camber set as negative as it can put on the knuckle adjustment. I am getting some 17" wheels with a better offset that will allow the wheel to sit more inside the fender. Will I want to run the OEM camber specs given the position of my axles with this current drop? Toe should always remain the same, right?
Here is a pic of the car now:
your cv joints are in jeopardy no matter what when you are lowered past a certain point (3" is not that serious). thats just something you have to live with.
fatory specs are numbers, not positions. i.e. factory specs may be 0* camber, 0* toe (example). after lowering you should try to adjust your suspension back to those numbers.
the damage to your suspension geometry is already done. the tweaks you are talking about are on a whole nother level (advanced suspension i.e. track racing) that is beyond me and i dont think you should be too concerned with. i would just focus on getting your tires planted square on the ground to reduce tire wear.
i would advise staying within the nominal front camber settings for even, and reduction of tire wear. your total toe should be within factory spec and if not, they can easly adjust that. the rears they can't really do much. i just got my alignment w/ my ksports and my total rear toe was off by .17 degrees but nothing to big.
rear = unadjustable
i wont even pay for a 4 wheel alignment. if they try to sell it to you leave (unless you're just curious).
i can't wait to see what my specs are. i'm way out of the "able to get in spec" range. right now i'm probably close to double digit camber. lol.
rear = unadjustable
but good thing is, i only paid $25 for 4 wheel alignment!
MaxLife17
Jun 27, 2019 01:37 PM
Max139617
Sep 20, 2015 07:09 PM
