04 I35 - engine knock?? HELP!
Old Aug 12, 2008 | 09:32 PM
GrandMoffJoseph's Avatar
So I've been battling an on again off again issue with my I35 that sounds to me like a rod knock. I've had it into the dealer like 5 times and they keep coming up empty, so I'm going to consult my usual mechanic, though he has never worked on this car before. BUT, I want y'all to lend your ears and offer some advice/feedback.
Please view the following video:
http://www.mst.edu/~jricca/I35engine.zip
When ice cold, the engine started so rough it sounded like a rod was coming through the hood. This is the first time that has happened in over 3 months. But, the knocking sound you hear in the video is pretty much constant, hot or cold.
NOTE: Car has 87K, is fresh on all fluids and tune up items
Old Aug 12, 2008 | 09:42 PM
KRRZ350's Avatar
Where is "The STL". Better off putting a car-part motor in it than dropping the tranny and upper pan and m.t.l. getting the crank machined.
Didn't watch vid, you-tube ftw
Old Aug 12, 2008 | 09:45 PM
STL = St. Louis.
Some web research is showing me that others who had this problem traced it to the serpentine belt for the A/C. Does that sound plausible?
What about the knock sensor?
Old Aug 12, 2008 | 10:07 PM
SVI30's Avatar
If you turn off the A/C, does the noise go away? What do you mean running rough? Does the engine vibrate more than before, or just the noise?
Old Aug 12, 2008 | 10:09 PM
A/C seems to make no diff. to my ears. As for the "rough" part...take the knock sound in the video and amp it by 10x...definately sounds metallic is nature...
Old Aug 12, 2008 | 10:14 PM
SVI30's Avatar
Take it to a shop, on a flat bed. Unless you are ready to tackle it yourself.
Old Aug 13, 2008 | 04:32 AM
brio_max's Avatar
Learning English...
How's the oil level?
KRRZ350's Avatar
Does it do it consistent enough that you could remove the serpentine belt for 10 minutes or so and know if it is gone or not? A problem with an accessory driven off of the serpentine belt is very plausible.
Rod knocks tend to go away once warm initially.
Can you get the video on you-tube?
Old Aug 13, 2008 | 06:46 AM
Oil level is good.
Also, I drove the car to work today (20 miles, all highway), and when I got to work, the noise was gone totally.
So, as shown in the video, the noise is there at idle, even when warm. However, it does not get louder with increased engine speed, regardless of temperature. ALSO, after a few minutes of driving, it goes away totally.
I'll try to get it on you tube tonight for y'all.
Old Aug 13, 2008 | 06:48 AM
But overall, the problem is not constant - as in it doesn't make this noise every time it starts cold. This is the first time this noise has been back like this in about three months...
/this is driving me nuts, lol
ballerchris510
Sep 23, 2015 08:46 PM
ballerchris510
Sep 11, 2015 05:29 PM
Hdnseek
Sep 9, 2015 05:55 AM
