04 I35 - engine knock?? HELP!
So I've been battling an on again off again issue with my I35 that sounds to me like a rod knock. I've had it into the dealer like 5 times and they keep coming up empty, so I'm going to consult my usual mechanic, though he has never worked on this car before. BUT, I want y'all to lend your ears and offer some advice/feedback.
Please view the following video:
http://www.mst.edu/~jricca/I35engine.zip
When ice cold, the engine started so rough it sounded like a rod was coming through the hood. This is the first time that has happened in over 3 months. But, the knocking sound you hear in the video is pretty much constant, hot or cold.
NOTE: Car has 87K, is fresh on all fluids and tune up items
![](https://maxima.org/forums/images/smilies/support.gif)
Didn't watch vid, you-tube ftw
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
Does it do it consistent enough that you could remove the serpentine belt for 10 minutes or so and know if it is gone or not? A problem with an accessory driven off of the serpentine belt is very plausible.
Rod knocks tend to go away once warm initially.
Can you get the video on you-tube?
Oil level is good.
Also, I drove the car to work today (20 miles, all highway), and when I got to work, the noise was gone totally.
So, as shown in the video, the noise is there at idle, even when warm. However, it does not get louder with increased engine speed, regardless of temperature. ALSO, after a few minutes of driving, it goes away totally.
I'll try to get it on you tube tonight for y'all.
But overall, the problem is not constant - as in it doesn't make this noise every time it starts cold. This is the first time this noise has been back like this in about three months...
/this is driving me nuts, lol
ballerchris510
09-23-2015 08:46 PM
ballerchris510
09-11-2015 05:29 PM
Hdnseek
09-09-2015 05:55 AM
