want new exhaust. but i want some preformance too.
So, i have a stock exhaust system on my max. just learned that headers would be to expensive and wont pass emissions. So i was thinking id just get a y-pipe and catback exhaust?
The sound im looking for is a low deep growl. And a somewhat loud rumble when rpms are dropping. What combination of y-pipe and catback should i get for that sound.
Instead of telling you to search this beaten to death topic I will provide the link to the exhaust sound STICKY
http://forums.maxima.org/5th-generat...und-clips.html
And if you have a 3.5 skip the Y-pipe, not worth the $.
thanks guys. But all the y-pipe, header, and "test pipe" (have no clue what they are) combination's are confusing. And i guess the problem is i think that the sounds will be different with a combination of the different brands or whatever. And how some people use a catback system but swap the muffler and stuff like that. Ill continue to search. But if someone knows a good combination, please let me know..
if you have an 01.....get a cattman y pipe, Meagan Racking catback......or you can opt for the magnaflow exhaust, or even the stock exhaust as the Meagan racing exhaust is a little louder than other members would like
Ok,i found what im looking for. This maxima sounds exactly how i was thinking. Its amazing.
and this guy has:
Hotshot headers
test pipe
2.5" catback
magnaflow resonator
obx muffler.
since i dont know too much about exhaust systems and what not. which of these would i need to achieve that sound. BTW i have a 2000 se. Id also like it to pass emissions too.
Thanks guys
http://www.youtube.com/watch?v=dwxy8IzLXiU
and this guy has:
Hotshot headers
test pipe
2.5" catback
magnaflow resonator
obx muffler.
Thanks guys
a "test Pipe" is a straight through resonated cat, you will not pass emissions if you have one.
You can pass emissions with headers and y-pipe and the catback is just about choice on sound really.
headers can pass emissions just as long as you have an o2 sim and they don't see it. (also before you go to get it done you have the car warmed up, removal precats can cause a failure as well if engine is not warmed to idle temp)
you should be okay in both situations as long as you have a main cat. The test pipe is a pipe section that replaces the main cat with a resonated pipe.
so to keep everything seperate from the engine, these are the different sections:
1. Headers
2. Y-pipe
3. Cat
4. B-Pipe
5. axle section muffler
those are all the bolt in exhaust sections. what you choose to replace is all dependant on what you want.
So the stock muffler has a thing in it that opens and closes under pressure and can i change just the muffler to get some sound...I would like to have a little growl but i don't want to lose my power or tq or my best option is to leave the stock system...
No i don't want a Ypipe and i don't want my pipe bigger i just want a little sound without losing power....
What should i do???
What should i do???
What should i do???
What should i do???
If you want power then do headers or a y-pipe. Increasing pipe diameter from the 2.25" stock piping to 2.5" piping is a good thing, you won't lose power, you will gain HP and TQ.
face...I am an ignorant a-hole haha.
ha, its all good. I always thought a resonator and a test pipe where the same thing. or are they? i still don't know cause some people have test pipes and resonators.
A resonator is a part inside the exhaust tubing that helps to quiet down the exhaust. Exhausts without them are a lot louder.
Test pipe replaces the main catalytic converter. A resonator is a secondary muffler, usually between the main cat and the rear muffler. It helps keep your interior quiet. You do want one.
James92SE
Oct 8, 2015 04:57 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
ballerchris510
Sep 10, 2015 09:35 PM
at this thread....
