want new exhaust. but i want some preformance too.
Old Sep 10, 2008 | 05:37 PM
mymaxi41691's Avatar
So, i have a stock exhaust system on my max. just learned that headers would be to expensive and wont pass emissions. So i was thinking id just get a y-pipe and catback exhaust?
The sound im looking for is a low deep growl. And a somewhat loud rumble when rpms are dropping. What combination of y-pipe and catback should i get for that sound.
Old Sep 10, 2008 | 05:39 PM
n3985's Avatar
大陆弟弟
Instead of telling you to search this beaten to death topic I will provide the link to the exhaust sound STICKY
http://forums.maxima.org/5th-generat...und-clips.html
And if you have a 3.5 skip the Y-pipe, not worth the $.
Old Sep 10, 2008 | 05:50 PM
Czerkas's Avatar
thats all you need bud.
next time just search
good luck on your quest.
Old Sep 10, 2008 | 06:28 PM
thanks guys. But all the y-pipe, header, and "test pipe" (have no clue what they are) combination's are confusing. And i guess the problem is i think that the sounds will be different with a combination of the different brands or whatever. And how some people use a catback system but swap the muffler and stuff like that. Ill continue to search. But if someone knows a good combination, please let me know..
Old Sep 11, 2008 | 06:36 AM
hi-tek22's Avatar
if you have an 01.....get a cattman y pipe, Meagan Racking catback......or you can opt for the magnaflow exhaust, or even the stock exhaust as the Meagan racing exhaust is a little louder than other members would like
Old Sep 11, 2008 | 08:06 AM
Puppetmaster's Avatar
That's the whole point. It is all personal preference and you are correct that everything sounds different based on components. You need to do your own research on what combos suit your needs and go from there, that's why the sound clips sticky and dyno sections exist. There is no one recommended combination.
Old Sep 11, 2008 | 01:18 PM
Ok,i found what im looking for. This maxima sounds exactly how i was thinking. Its amazing.
and this guy has:
Hotshot headers
test pipe
2.5" catback
magnaflow resonator
obx muffler.
since i dont know too much about exhaust systems and what not. which of these would i need to achieve that sound. BTW i have a 2000 se. Id also like it to pass emissions too.
Thanks guys
http://www.youtube.com/watch?v=dwxy8IzLXiU
Old Sep 11, 2008 | 02:36 PM
sergey85's Avatar
you cant get those headers no more company closed down
Old Sep 11, 2008 | 05:04 PM
sublime258's Avatar
Y-pipe and test pipe are the same thing.
Get a Catmman y-pipe and cat-back exhaust.
Old Sep 11, 2008 | 05:55 PM
DrunkieTheBear's Avatar
Turbo'd Saab
a "test Pipe" is a straight through resonated cat, you will not pass emissions if you have one.
You can pass emissions with headers and y-pipe and the catback is just about choice on sound really.
Old Sep 11, 2008 | 06:17 PM
ahh, ok. So i think im gonna settle on the megan racing catback.
Old Sep 11, 2008 | 06:53 PM
Pearltt's Avatar
You won't be sorry...just got mine a few months ago....Love it!!!!
Old Sep 11, 2008 | 07:55 PM
dineth00i30's Avatar
wait, so if you get a y pipe you wont pass emisions or thats only for test pipes and headers?
Old Sep 11, 2008 | 07:58 PM
AceofSpds's Avatar
wat
depends on what kind of testing, if they have a sniffer probably not.
Old Sep 11, 2008 | 08:04 PM
Turbo'd Saab
y-pipe can pass emissions easy
headers can pass emissions just as long as you have an o2 sim and they don't see it. (also before you go to get it done you have the car warmed up, removal precats can cause a failure as well if engine is not warmed to idle temp)
you should be okay in both situations as long as you have a main cat. The test pipe is a pipe section that replaces the main cat with a resonated pipe.
so to keep everything seperate from the engine, these are the different sections:
1. Headers
2. Y-pipe
3. Cat
4. B-Pipe
5. axle section muffler
those are all the bolt in exhaust sections. what you choose to replace is all dependant on what you want.
Old Sep 11, 2008 | 08:10 PM
kcxd35's Avatar
So the stock muffler has a thing in it that opens and closes under pressure and can i change just the muffler to get some sound...I would like to have a little growl but i don't want to lose my power or tq or my best option is to leave the stock system...
No i don't want a Ypipe and i don't want my pipe bigger i just want a little sound without losing power....
What should i do???
Old Sep 11, 2008 | 08:18 PM
Turbo'd Saab
What should i do???
If you just want sound then just get a catback or axleback muffler
If you want power then do headers or a y-pipe. Increasing pipe diameter from the 2.25" stock piping to 2.5" piping is a good thing, you won't lose power, you will gain HP and TQ.
Old Sep 11, 2008 | 08:29 PM
irish44j's Avatar
retired moderator
at this thread....
Old Sep 12, 2008 | 11:02 PM
sublime258's Avatar
I stand corrected...never knew the difference. From what I've read from people here on the .org, I always thought that a test pipe and y-pipe were the same. But now I know...to mymaxi41691: sorry for the face...I am an ignorant a-hole haha.
Old Sep 13, 2008 | 09:25 AM
ha, its all good. I always thought a resonator and a test pipe where the same thing. or are they? i still don't know cause some people have test pipes and resonators.
Old Sep 13, 2008 | 09:56 AM
sublime258's Avatar
A resonator is a part inside the exhaust tubing that helps to quiet down the exhaust. Exhausts without them are a lot louder.
Old Sep 13, 2008 | 09:58 PM
Scottwax's Avatar
That's Mr. Detail to you
Test pipe replaces the main catalytic converter. A resonator is a secondary muffler, usually between the main cat and the rear muffler. It helps keep your interior quiet. You do want one.
Old Sep 14, 2008 | 06:55 AM
Turbo'd Saab
The test-pipes come resonated, but you do want another main resonator
James92SE
Oct 8, 2015 04:57 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 10, 2015 09:35 PM
A32goldylocks
Sep 2, 2015 06:39 AM
