Cat Question
Old Nov 11, 2001 | 04:48 PM
SkylineGTR's Avatar
Cat Question
i have a 5th gen auto fed spec, if i were to replace the cat with a straight pipe would i get any engine lights or safe mode or anything like that?
me and my friend just removed the cat on his CRX and damn is it loud, im jealous,
i wanted to see if that would be possible with the max without any problems.
Old Nov 11, 2001 | 05:10 PM
UMD_MaxSE's Avatar
Got Bent?
you may get the check engine light, but you will not go into safe mode or anything like that. It shouldn't affect performance in any way. But, replacing just the cat without replacing the y-pipe, won't get you a lot of gains....
Old Nov 11, 2001 | 05:38 PM
SkylineGTR's Avatar
thanks, thats all i needed to know hehe. i asked because i plan on getting the ypipe real soon and i thought if i could change the cat at the same time.
Old Nov 11, 2001 | 05:55 PM
UMD_MaxSE's Avatar
Got Bent?
no problem... since you have fed spec emissions, if you replace the y-pipe and replace the main cat with a straight pipe, you will surely get a check engine light because you will have no cats in the exhaust at all. But it should be no big deal. You could also replace the stock cat with a Random Tech hi-flow cat.... no check engine lights then.....
Old Nov 11, 2001 | 06:03 PM
Foglght's Avatar
There is a Cat monitor Hego (o2 sensor) right in back of your cat. If you replace it with a straight pipe, you need to drill and tap a hole for the hego.
lrb6805
Sep 18, 2015 07:07 PM
pears
Sep 18, 2015 05:25 AM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
