*** Need to know fast! What Amperage is the alternator in my 95SE?
I'm going to have my friends shop swap the bad alternator for me but I need to know what amp. it is 110 or 125.
Thanks!
Jim
Thanks!
Jim
Search came up with conflicting answers:
http://forums.maxima.org/search.php?...g&pagenumber=1
Some think it's 110A, while others think the GLE has a 120A to 125A output.....
I would just get the higher rated one.
Jim,
A check with carparts.com's database seems to confirm:
A)95 to 96 models are 110A and 125A for Cali and non-Cali spec cars, respectively.
B)97 to 99 models seem to depend on the model, with 100, 110 and 125A output alternators depending on trim designation......
C)Do yourself a favor and just get the 125A spec one.
Nissan cost-cutting at it's finest.
Hitachi - LR1125-702 OEM part number:2310031U02R
Nominal Rating 125 A
Ground Polarity Negative
Hot Output Current
Note: Minimum revolution should be less than 1100 rpm under no-load when 13.5 volts is applied.
>36 A at 1300 rpm
>94 A at 2500 rpm
>123 A at 5000 rpm
Minimum Length of Brush >0.2362 in
Brush Spring Pressure 3.60-12.34 oz
Slip Ring Minimum Outer Diameter >1.024 in
Rotor Resistance 2.35 ohms
Hot Output Current
>36 A at 1300 rpm
>94 A at 2500 rpm
>123 A at 5000 rpm
Originally posted by bill99gxe
Jim,
Jim,
Jim
Originally posted by JJW95SC
Bill, getting a higher rated alternator than that which came with the car couldn't cause any problems. I'm assuming fitment is the same...
Jim
Jim
Bill, getting a higher rated alternator than that which came with the car couldn't cause any problems??? I'm assuming fitment is the same...
Jim
Jim
Hot Output Current
>36 A at 1300 rpm
>94 A at 2500 rpm
>123 A at 5000 rpm
Hot Output Current
>36 A at 1300 rpm
>94 A at 2500 rpm
>123 A at 5000 rpm
Also, I remember some time last year I asked the parts dept of the local dealers about the same issue. they told me the part numbers for the GXE, SE, GLEs were the same, thus nullifying the myth that "cars with heated seats have bigger alternators". The higher output appears to be california/non california emissions based.
www.alldatadiy.com , however, it is a subscription site.
TallTom
57
Oct 14, 2025 05:16 PM
