is it my window motor or regulator?
the rear window went out awhile ago and i replaced the regulator, that window had completely shut off all at once which i guessed was the regulator snapping or something.
now ive got both front windows acting funny the drivers side shut off completely while it was open all the way and i assummed it was the regulator but the next day the window worked perfectly then the passenger side started acting funny because sometimes it will stop while coming up or puase inermittently and slow down i now have to wiggle the window to get it to come up but this only happens sometimes usually it works perfectly
so should i replace the motors or the regualtors in the front driver and pasenger side wondows?
regulator holds the window in the track and provides a track for the window to raise and lower on. If the window is stable then I would look at the electronics. And if you have more than one that is acting up i'd be leaning towards it being the master switch.
eh, if it's trying, then the switch is fine. you might have worn out tracks that are grabbing the glass on its way up, causing extra resistance, and a slower climb. your window wiggles alot in the track when halfway up, doesn't it?
I have some of the same problems with my windows i have 3 windows that will not do anything and 1 window that will move but get stuck and makes a popping noise when i press the switch to let it down and out of the 3 windows that will move the driver side winodw falls down so i had to put a broom handle to hand it in place.. so if anymore can get me going into the correct direction on these issue it would be helpful
the one you had the broom handle in is definetly the regulator it maybe for all four of them or some of them might be of track but the other two that dont move sounds more like a dead motor to me
my window problem automatically fixed itself which tells me it was the window master switch and it will probably break just as magically as it fixed itself
2 front windows do that. Is it the regulator??? Theres no popping noise or anything, but they'll just stop sometimes. Maybe i need to spray some WD-40 on the insides?? lol
/Thread
I'VE BEEN BRINGING MY DADS MAXIMA BACK TO LIFE AND ONLY THE FRONT PASSENGERS SIDE WOULD WORK. cHANGED THE TWO REAR REGULATOR AND MOTOR AND THEY WORK GREAT. BUT MY DRIVERSIDE WILL NOT BUDGE!! i CAN HEAR IT ATTEMPT TO MOVE, BUT NOTHING HAPPENS. i CONNECTED A NEW MOTOR AND REGULATOR, BUT THAT WONT WORK AT ALL. tRIED A USED MASTER WINDOW SWITCH AND NOTHING WORKED! doNT KNOW WHAT TO DO, chANGED THE WHOLE DOOR? PLEASE HELP!!!
Thanks!
Drivers side window stuck in up position. I do hear a sound when I attempt to lower it but nothing happens. All other windows work. Attempted to change regulator and motor, but upon checking the new motor by plugging it in, it doesn't move at all, no sound. Tried a new (used ) master window switch, but then none of the windows work. Tried forcing window down, but no luck, seems stuck! any suggestions would be appreciated!
Thanks!
if it's just a faint click, probably a dead motor (list price is $350!!! so get a good used one here http://forums.maxima.org/1st-3rd-gen...-1981-1994-44/)
if it's stuff in the door trying to move but can't, then it's the regulator cable guides that are broken. get a new regulator here http://www.courtesyparts.com/80701-r...4-p-44776.html or see if anyone who's parting cars out has any here http://forums.maxima.org/1st-3rd-gen...-1981-1994-44/
Thanks for the reply caped! I have a new regulator and motor, but when i plug it in to test, it doesn't move at all, i don't even hear the sound (faint clicking noise). THats why i thought it was the master switch, but when i tried a different one , none of the windows worked ( maybe just a bad switch?) The car sat for a few years and it got a little rusty on the inside ( i.e, door locks dont work ) Any other suggestions, thanks.
regulators are 30 bucks new and 60 bucks for the new motor (which u most likely dont need)
dont buy courtesy nissan this is where i bought all three regulators and they all work fine: http://www.am-autoparts.com/AM/Windo...n/Maxima/1993/
AaronL
Aug 8, 2020 10:31 AM
