strange grind/squeak sound
I was driving to Orlando yesterday, and a little bit before I get to my friend's house I hear a strange grinding that is coming from the front driver side tire and at certain speeds it tends to squeak. It's causing some vibration in the steering wheel and and it's kinda scaring me. I know the tie rod needs to be changed, could that cause the grinding/squeak that i keep hearing.
it could be a number of things. usually when a cv joint goes out it makes a popping noise when you take turns. it also could be a bad bearing or the brake pad could just be rubbing against the rotor.
cv joint usually pops but if the bolt on the end is lose i guess it could slide making a grinding noise...
your best bet is jacking it up and doing a visual check to see if anything is lose or doesnt look right, put it on neutral and give it a spin too. Your problem is most likely brakes or half shaft related
i think you might have a bad bearing. if you can push and pull the wheel toward you and away then its mostly a bad bearing. im actually riding on a bad one now and i can pull it away and toward me about an inch or two when i jack it up
.i plan on getting it fixed in a few days.
i dont no then. my next guess would be bad ball joint but you said it had a noise to it. a bad ball joint could make your car vibrate but wouldnt really make a noise. i would just jack it up and take your wheel off and inspect it and see if theres anything that looks abnormal. if you cant find whats wrong with it have it inspected by a mechanic.
so i jacked the car up and checked it again all i can see is a tie rod that needs to be replaced and probably the cv joints, i'll probably end up taking it to a shop to have it looked at. any suggestions on types of shops i should take it to have this looked at?
but back to the point to my thread, i noticed that sometimes when i step on the clutch to shift there is thunk. it sounds almost like you're throwing a rock at a half full water heater any suggestion?
Hey guys, I was having a similar problem to mistur_sleepyass, except the grinding / rubbing is coming from the right side. It's progressed quickly, originally it only made a wum wum wum wumwumwum sound under braking, and I thought the rotors were bad.
A little later, during a trip to Vegas I noticed a strange scratching / grinding coming from the wheel, like a piece of metal wire was caught in the brakes or something. I brought it in for routine service (rotate tires and oil change) and the scratching went away.
Then it started making the spinning wum wum sound without the breaks at freeway speeds, so I thought maybe the the lugs were loose (I just had the tired rotated). Not the case.
Well, yesterday it started making a rubbing / grinding sound at low speeds too. It went away after a bit so I was planning at getting it looked at end-of-week.
Now, my girlfriend texts me this morning (she has my car) and tells me she can't hardly turn the steering wheel.
Any thoughts?
P.s My car is an 03' SE auto with about 99k miles.
Any thoughts?
Any thoughts?
Any thoughts?
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
