axle seal question.....
Old Dec 26, 2008 | 07:17 PM
max ride 41's Avatar
ok, so both sides are leaking, not bad though. at what point do i need to consider re-doing them??? do i lose tranny fluid or oil or both?? not sure cause i didnt see it, my mechanic told me about it. cost to repair?? thanks in advance>>>>
Old Dec 26, 2008 | 07:19 PM
Gtpowered4.6l's Avatar
Seals can be had for $20. It doesnt take that long to tear apart. I have done it once. Wasnt too bad. I have to retear back apart now to put in new axles.
Old Dec 26, 2008 | 07:27 PM
so, you have a 5 speed trans, what are the differences between auto and manual? and how do you determine when an axle is shot?? does the car hop sideways??? cause mine does that, but i also need new lca's. i have 186,000 on my 95 auto, but i have a plethera of other work to do. merry xmas maxy.....
Old Dec 27, 2008 | 12:07 AM
pmohr's Avatar
No more Maximas...
What are the differences between auto and manual? I hope you mean as far as replacing the axle seals? Not much, really. Pull the axle, replace the seal, replace the axle.
A failing CV joint will typically give you clicking when you go around corners, usually at slow speeds.
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
mpbclutch33
Dec 26, 2015 11:11 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
