5th gen parts fit 6th gen?
Old Jan 15, 2009 | 05:35 PM
silverbeast2004's Avatar
hey guys i'm pretty sure it's been asked and discussed and i've searched but found nothing. will 5th gen performance parts fit 6th gen? for example, headers? thanks in advance!
Old Jan 15, 2009 | 05:41 PM
04MAX_ILLIN's Avatar
Im gonna have to say i doubt it but this is with no knowledge of the 5th gen at all. Reason being that if 5th gen headers fit the 6th gen then nearly ALL of us on the A34 side would have headers on our cars already.
Old Jan 15, 2009 | 05:49 PM
yea i was thinking the same thing. But if i'm not mistakened, the 5th gen has the same engine, or is very similar to the 6th gen engine.
Old Jan 15, 2009 | 06:17 PM
Feldman's Avatar
i think the 5.5 gens technically would bolt up to the 6th gens but i think i remember cattman having trouble with clearance issues and cel's on the 6th gens so i bet they arent swappable
Old Jan 15, 2009 | 08:31 PM
Hmm that sounds more like it actually. I think the difference is egr and no egr. No egr on the 5.5 The 6th gen does have 1.
Old Jan 16, 2009 | 05:44 PM
So then it's basically just the clearance. And can't we always get an egr port put on so it fits?
Old Jan 16, 2009 | 06:46 PM
KCMAXX's Avatar
KC's FINEST
You'd be better off asking the fifth genners.
There's also a performance/motor section.
Old Jan 16, 2009 | 07:03 PM
Puppetmaster's Avatar
You can't use 5.5 Gen headers on a 6th Gen or Alti, at least, not the way they come from the manufacturers. Take a look under each and you will see why.
4th, 5th, and 5.5 Gen Maximas have a subframe piece commonly referred to around here as a cross member while the 6th Gens have a cradle looking subframe. The y-pipes therefore have to be completely different. You could use the headers with a custom y-pipe, but I'm not sure how cost effective that would be as opposed to just buying a set from Cattman. Even then I'm not sure the angle at which the collectors from each bank comes down would work, because the headers are designed to go with a specific y-pipe.
5.5 Gen (Derrick2k2SE and mine):
6th Gen (chernmax's):
From here: http://forums.maxima.org/4189488-post131.html
Old Jan 16, 2009 | 07:09 PM
The headers LOOK similar in the pictures, but they are different. The main difference is still the y-pipe though.
Compare here:
http://forums.maxima.org/5th-generat...es-4-38mb.html
And this picture of Gen II Cattmans for the prev gens:
Vs chern's picture of his old Hotshots here:
You can see that the rear bank collector flange on the 6th Gen headers curves toward the front of the car while the 5.5 Gen header collector flanges point straight down, from what I can see from the pics.
Old Jan 16, 2009 | 09:19 PM
jsmithsole's Avatar
*moderator*
I would assume if the 5th gen headers did fit there'd be alot of us that would of had them along time ago and Cattman would not have taken the time to develop 6th gen headers....
Old Jan 17, 2009 | 06:51 AM
That's the short answer.
Old Jan 18, 2009 | 05:14 PM
Maxpwr13's Avatar
All good information...Thank's
CRizz
41
Jun 7, 2021 05:42 AM
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
2k0to2k3
Aug 18, 2015 09:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
