DTC 0707 after running at the Pike last night
Old Nov 17, 2001 | 10:12 AM
deezo's Avatar
Will I be fine running on a faulty Rear O2 sensor for a couple of weeks?
Old Nov 17, 2001 | 10:17 AM
NickStam's Avatar
Re: DTC 0707 after running at the Pike last night
is it continously on? or has it gone off?
Old Nov 17, 2001 | 10:26 AM
deezo's Avatar
Re: Re: DTC 0707 after running at the Pike last night
I reset the ECU and its off now.
It tripped the code when I was cruising home last night.
Old Nov 17, 2001 | 10:08 PM
deezo's Avatar
bump
Old Nov 17, 2001 | 10:29 PM
190hpKiLLA's Avatar
Granny Driven
Originally posted by deezo
bump
A while back when my O2 sensor got busted Daniel B Martin told me not to run for long time cause it will fry my CAT converter. So I guess a 2 weeks wont do much unless you drive a lot.
Old Nov 18, 2001 | 12:12 AM
Confused's Avatar
Permanent Maxima.org Resident
DTC 0707 is easy... everybody gets that... i looked in the fsm and it says "I beat Doug"
Old Nov 18, 2001 | 07:41 AM
deezo's Avatar
HAHAHAHA!!!!!!!
Old Nov 18, 2001 | 09:03 AM
Synki's Avatar
4th gen FSM
Old Nov 18, 2001 | 07:03 PM
deezo's Avatar
Originally posted by Synki
4th gen FSM
Old Nov 18, 2001 | 07:08 PM
black97max's Avatar
0707 Code
I'm pretty sure I have the same code with my car. I thinks its "rear heated 02 sensor", but mine was caused from using a 1995 modded JWT ECU in my 97. I havent had a problem with my car since it came on 8 months ago.
Old Nov 18, 2001 | 07:17 PM
deezo's Avatar
Re: 0707 Code
It is the rear o2 but after resetting the ECU, it didn't show back up.
Old Nov 18, 2001 | 07:40 PM
theblue's Avatar
I've been running without a rear O2 for 8 months now... make your own conclusions.
Old Nov 18, 2001 | 08:02 PM
deezo's Avatar
Is it non-functional or did you remove it?
Old Nov 18, 2001 | 08:15 PM
black97max's Avatar
If there is a problem the MIL will turn on again in a ~100 miles or so.
Old Nov 18, 2001 | 08:20 PM
theblue's Avatar
I have the apexi catback so there is no hole for it... its just tied up down there
Old Nov 18, 2001 | 08:42 PM
black97max's Avatar
TheBlue-Thats probally the secret to you running those great times
Old Nov 19, 2001 | 07:03 AM
Lime's Avatar
LOL! Harsh, man...he found the nitrous problem.
Old Nov 19, 2001 | 07:07 AM
Sprint's Avatar
no don't tell him.. he SHALL find out
Old Nov 19, 2001 | 08:38 AM
theblue's Avatar
I heard that sprint didn't use his NOS quick enuf and it got old and didn't work. but that's ok, I've grown to expect amature mistakes from sprint
Old Nov 19, 2001 | 08:43 AM
Sonic's Avatar
That wasn't nice Aaron. Stop taking everything out of your car at the track, thats a newbie thing to do.
Old Nov 19, 2001 | 08:45 AM
deezo's Avatar
Anyone still watching the vid?
Sprint's Avatar
actually i had a NOS part leak.. not an install problem.. and maybe if i take my seats out.. i can run 12's
Old Nov 19, 2001 | 08:52 AM
theblue's Avatar
I guess I need to work on my info links from the pike :-) if you think you can run 12s by taking out the seats then do it. You know you can't and this is why you just like to give the people who are fast a hard time.
Old Nov 19, 2001 | 08:57 AM
deezo's Avatar
Didn't the nitrous get old or was it just your other problem Sprint?
Old Nov 19, 2001 | 09:16 AM
Sonic's Avatar
Me.
Old Nov 19, 2001 | 09:17 AM
Sonic's Avatar
Are you referring to me?
Old Nov 19, 2001 | 09:45 AM
theblue's Avatar
no... I need somebody who can keep up and tell me the results... j/k maybe I should use you
Old Nov 19, 2001 | 10:10 AM
Sonic's Avatar
I am slow.
Old Nov 19, 2001 | 10:12 AM
theblue's Avatar
I am slow.
so if you are slow and you can beat sprintmax then _______________ I know I give you guys a hard time, but you give it back just as much
Old Nov 19, 2001 | 10:22 AM
Sonic's Avatar
I'm joking with the I'm slow, hell my car is WAY faster now, and that's WITHOUT the NOS.
captchaos
Mar 15, 2016 12:18 PM
cruce91
Sep 20, 2015 10:23 AM
kadespraggins
Sep 14, 2015 12:04 AM
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
