Quick question about axle removal
Old Mar 8, 2009 | 06:22 PM
Goran's Avatar
I having little trouble pulling my passenger side axle out. Don't have a service manual and can't remember exactly how to do it now. I did it years ago on my old max and didn't have any problems then. My question is where am I supposed to pry it apart, #1 mark or #2? Thanks guys
Old Mar 8, 2009 | 08:07 PM
oldngivout's Avatar
Willing to learn
Number 1.
Also, try installing one of the three bolts only a few turns, then hitting the head with a hammer. Might help jar it loose.
You may have to use a long drift, since a hammer probably won't go in there.
Old Mar 8, 2009 | 08:20 PM
Drockb418's Avatar
.....ya its a pain i could never break it loose so i had to take the base of the old one and put the shaft of the new one into the old one.
Old Mar 8, 2009 | 08:34 PM
NissanTun3r's Avatar
I replaced both my axles last year. What a PIA. Seriously those bishes were stuck in there!
I literally just grabbed the axle, and pulled as hard as I could! When it came out I was pulling so hard I flew backwards and landed on my back!
Old Mar 8, 2009 | 09:10 PM
Wmaxima's Avatar
^^^^^ HaHa Thats pretty much what happened to me. I just kept yankin on the bish until it finally broke loose. Putting it back in was a little easier.
Old Mar 8, 2009 | 09:19 PM
pmohr's Avatar
No more Maximas...
Remember to put some anti-seize on the support bearing when you install the new axle, to make it easier for next time.
Old Mar 8, 2009 | 11:21 PM
Kaane's Avatar
I just did both axles, and I removed the axle with the whole bracket. I just removed the 3 screws holding the bracket to the block and wiggled the whole assembly out. Once removed it's easy to remove the bracket from the axle.
Old Mar 9, 2009 | 05:08 PM
Goran's Avatar
ok, thanks guys. I'll try it and see how it works.
Old Mar 21, 2009 | 02:05 PM
Craftyanp's Avatar
I've been trying to replace the passenger side CV axle on my 6 speed 2002 Maxima. I am on my 3rd axle and all three are approximately 2-3 inches short. Any ideas as to what the correct part number is. I've given all the important info to the parts people: 3.5 litre 6 speed, 2002......... and they keep giving me the same length part. I've even used different parts dealers.
Old Mar 21, 2009 | 02:07 PM
pmohr's Avatar
No more Maximas...
Are you getting these from parts stores?
They're giving you axles for the 4AT.
Probably the only place you're going to be able to get one is raxles, the classifieds here, or a junkyard.
Old Mar 21, 2009 | 09:47 PM
rroderiques77's Avatar
Demodded and Forgotten
Air hammers work like a charm to remove them..
kingw323
20
Oct 21, 2015 08:36 AM
Jcof88
Sep 9, 2015 03:11 PM
soloist3
29
Sep 1, 2015 03:47 PM
classymax420
Aug 6, 2015 06:35 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
