Any Ideas How To Remove The Tiny Injector Screws?
How can I get these out if the screws are all stripped. Why don't mechanics use anti-seize. It's as if they want their parts to break.
Good idea by the way - the guy who replaced those screws with cap screws, and his spec is correct. 8mm Socket.
(Please don't tell me I would have to individually drill them out. If so, I'm just leaving them alone)
There is a hammer tool which you can insert a large screw driver end into. You hit the tool with a hammer and it rotates each time you hit it, acting like an impact drill. Also, with hitting it with a hammer, you are creating significant downforce onto the screw which helps prevent further slipping. My experience, one or two taps then you can unscrew them by hand. I forget the name of the tool. Anyone know?
Can't hurt anything unless you hit the injector with the hammer! The rail is well supported and the injector are in the rail. I had to use an impact screwdriver as well! Remove the fuel rail off the engine it'll be easier!
if the rail is already out of the car tho, just go straight for the vicegrips.
i used a set of vice grips. Good luck.
ef9
Sep 10, 2015 10:35 PM
