Water pump service.
Old May 7, 2009 | 12:09 AM
whiteSE's Avatar
Water pump service.
i read all of the write ups. and its actually pretty simple for me. i also bought a bunch of tools that i want to use already....why i made this thread is to ask about one of the steps.
1. when u remove the cover, is the timing chain tensior right behind it? and in front of the water pump?
2. and does it sorta pop out at a angle when u remove the timing cover? or is it in a case sorta thing....(pic 1 being the case) that u pull down. (or is that the tensioner at all in the picture?)
3 and also, is there a bolt or nut or a drain plug on the block where i can drain all of my coolant? or water in my case?
sorry for the newb questions, i just want to do this right. don't wanna screw it up.
Old May 7, 2009 | 07:03 AM
pmohr's Avatar
No more Maximas...
The tensioner and the water pump are behind different covers.
There's a drain plug directly beneath the water pump:
Are you removing the timing cover, or just the access covers? Your question asks one, you implied the other. The tensioner will come right out.
There are several coolant drain plugs on the block, but you don't really need to use them.
Old May 7, 2009 | 09:30 AM
whiteSE's Avatar
that actually makes a lot more sense now. thanks
whiteSE's Avatar
pmohr, do u work for the org? u always on her, and always useful inforamtion lol
Old May 7, 2009 | 11:14 AM
96blackmaxSE's Avatar
boost me.....
250K a year.....
Old May 7, 2009 | 05:27 PM
Product_Of_Korea's Avatar
he is just the human fsm
Old May 7, 2009 | 05:29 PM
pmohr's Avatar
No more Maximas...
Originally Posted by 96blackmaxSE
250K a year.....
Hell, I wish.
Old May 8, 2009 | 10:29 PM
whiteSE's Avatar
so i started today at 4:30 and had to pack it up at 8:30 and all i did, was take everything apart. tommorow, i pop out the pump itself, and put everything together. its a freaking pain in the ****
Old May 8, 2009 | 10:35 PM
pmohr's Avatar
No more Maximas...
Just ensure that you don't get the chain caught on the pump.
Also, do you have the correct bolts for jacking the pump out? Should be 8x1.25.
Here's what I used, right about the perfect length to use a ratchet wrench on them comfortably:
Old May 8, 2009 | 10:40 PM
whiteSE's Avatar
i forgot to buy them with the pump....but ill get them tommo. i bought the pep boys pump. u guys think it'll be crap?
Old May 8, 2009 | 10:45 PM
pmohr's Avatar
No more Maximas...
Should be fine, short of a factory defect. I've been running on an AZ pump for what, 4 years now.
Old May 9, 2009 | 02:39 PM
whiteSE's Avatar
cool, i finally got it all back together, and its working. sounded like a deisl at first, cause of the chain, but not to bad.....but when putting it all together, somehow my idler got screwed up. (tensionor pulley) i bought another one, gonna put it on on monday. thanks a lot guys, or guy (pmohr)
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
