Stupid oil changer
Old May 12, 2009 | 05:14 PM
mahanddeem's Avatar
Stupid oil changer
He put about 5 quarters after draining the old engine oil (filter also replaced).......will be there any dangerous problem that needs immediate interaction?
I discovered that after I returned home and checked the dipstick ...
Old May 12, 2009 | 05:37 PM
JwaxMax99's Avatar
See, that's why you change your own oil!
(drain a little out)
Old May 12, 2009 | 05:43 PM
pmohr's Avatar
No more Maximas...
Your engine can't run on 5 quarters.
It's only 3/4 quart overfilled, it won't cause any immediate or extreme damage. Just drain out the extra when you get a chance.
Old May 12, 2009 | 05:46 PM
mahanddeem's Avatar
or the 167k engine will burn it in 1 month
Old May 12, 2009 | 05:48 PM
JwaxMax99's Avatar
It's not 5th gen 3.5L.
Old May 12, 2009 | 07:46 PM
mahanddeem's Avatar
...........something funny...idiots mechanics
Old May 12, 2009 | 07:48 PM
JwaxMax99's Avatar
...but you continue to take your car to these idiots?
Old May 12, 2009 | 08:18 PM
mahanddeem's Avatar
F u c k me if I will again
Old May 12, 2009 | 08:19 PM
JwaxMax99's Avatar
Good answer!
Old May 12, 2009 | 11:49 PM
tosheto's Avatar
haha. I suggest you go and **** them!
Old Nov 3, 2009 | 10:42 PM
VVS_75's Avatar
Pretty much have the same experience at last oil change. So now I am looking for used cheap jack stands, so I don’t have to deal with auto shop morons.
Does anybody know tip or trick to check level on dipstick? Every time I try to read the level it’s just guessing. I tried to remove the dipstick in lots of ways and still no luck, every time I get different reading and every time it covered in oil over the FULL mark.
Old Nov 4, 2009 | 04:13 AM
AEMAXIMA01's Avatar
Search next time.
http://forums.maxima.org/5th-generat...oil-level.html
http://forums.maxima.org/5th-generat...difficult.html
Old Nov 4, 2009 | 08:00 AM
pavelsmax's Avatar
In my stock ride height 95 gxe I can change my oil without jacking it up at all. Its tough and much easier if you remove the right front fender splash gaurd but possible.
Old Nov 4, 2009 | 10:21 AM
maxirob's Avatar
Check your oil first thing, before starting or running the engine. Pull the dipstick once, wipe clean with a paper towel, reinsert dipstick all the way in, then pull back out and read level. To change the oil - have synthetic 10W30 and a filter on hand. I run engine to normal op temp then run up on ramps, have a fram quick change drain bolt valve installed already and mines done in 20 minutes tops. Beats going to the idiot-hut-oil- change-overfill-to-cover-my-a$$-place. Had enough of that...
Old Nov 4, 2009 | 11:09 AM
mahanddeem's Avatar
Our cars use 5W30.......not 10W30
Old Nov 4, 2009 | 11:29 AM
wxm's Avatar
wxm
10W30 will be fine for the warm weather area.
Old Nov 4, 2009 | 11:48 AM
Q8BallMAXIMA's Avatar
This is a perfect example of why most orgers work on their own cars....especially basic maintence items.
I think whatever mechanic that changed your oil doesn't know how to read the specs and measure to those specs I would then then ask them to give my $$$$ back for the s*** job they did.
Old Nov 4, 2009 | 01:02 PM
maxirob's Avatar
Yes, sorry 5W30 is preferred, but here in Texas, no need for it! In fact, it's hard to find in stock anywhere 'round heh.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
