1999 Compression Test Results
Old Jul 11, 2009 | 06:29 PM
Maximeltman's Avatar
Did a test, and this is what I got:
(BTW engine was just below operating temp because we had to disassemble the coils an plugs and all)
210 210 210
205 210 195
Is this alright? Maybe a bit of carbon buildup but not bad?
And if I had a bent rod then it would probably be lower than 195? Because that's the cylinder that had hydro locked on me..
Old Jul 11, 2009 | 06:34 PM
Fadrvr's Avatar
As long as all the cylinders are around the same, looks really good.
You only did three cylinders or am I missing something?
Old Jul 11, 2009 | 06:36 PM
all six
210 210 210
205 210 195
Haynes states 185 or so psi though
Old Jul 11, 2009 | 06:40 PM
Fadrvr's Avatar
Oh alright. Missed the top three. Looks like you have a healthy VQ. My teggy read 140psi across the board. Then again Honda's are low compression and my car has 280k.
Old Jul 11, 2009 | 06:57 PM
shadyonedeath's Avatar
how do u do a compression test?
Old Jul 11, 2009 | 07:05 PM
See I hydro locked the one that reads 195psi, because I had a faulty fuel injector that was basically pouring gasoline into the cylinder(lost a small O-ring)...and whenever I tried to start it went "CLUNK" so I hope that nothing internally got damaged...I had it first towed to the dealership, and the douchebags at the dealership started it and those ******** may have ****ed it up big time; You'd think that they would know that it was hydro locked and to at least first relieve the cylinder of the fluid built up instaed of just ****ing persisting to start it until it goes .. Now when I have it running, it's either smooth or rough, So I did the compression test to maybe indicate damage inside.
Shadyonedeath:
1 remove all spark plugs after warming engine to normal operating temps and
2 relieve fuel pressure
3 connect the compression reader to where the plugs would go
4 crank engine to get each cylinder compression
Old Jul 11, 2009 | 07:08 PM
Fadrvr's Avatar
Yea it involves buying a compression gauge. I think they run 20 bucks at AdvanceAuto.
http://www.geocities.com/dsmgrrrl/FAQs/compression.htm
Old Jul 11, 2009 | 07:12 PM
thanks! good thread
Old Jul 11, 2009 | 07:30 PM
pmohr's Avatar
No more Maximas...
Originally Posted by Maximeltman
Shadyonedeath:
There's more to it than that. You need to block the throttle WOT, and preferably have it on a battery charger. And not only relieve the fuel pressure, but you want to disable the pump (or injectors) as well.
Old Jul 11, 2009 | 07:33 PM
o yea forgot the WOT thing add that and pulling the pump fuse too
Old Jul 11, 2009 | 07:35 PM
Soo...back to my original concern, these numbers seem a bit high or maybe it's because the engine was not right a OT?
Old Jul 11, 2009 | 07:36 PM
pmohr's Avatar
No more Maximas...
Your results are fine. Did you try a wet compression test on cylinder 6?
Old Jul 11, 2009 | 07:38 PM
pmohr's Avatar
No more Maximas...
It doesn't need to be exactly at operating temp, it's not extremely important overall.
If you were concerned about these numbers, did you search for others?
http://forums.maxima.org/5th-generat...00-maxima.html
http://forums.maxima.org/4th-generat...plug-coil.html
http://forums.maxima.org/5th-generat...2k-maxima.html
http://forums.maxima.org/general-max...e-results.html
...etc.
Basically if you're concerned about the slightly high readings, run some engine cleaners, see what happens.
no....I read about that AFTER I put everything back on If I had a bent rod, would I def know it?
Old Jul 11, 2009 | 07:47 PM
pmohr's Avatar
No more Maximas...
Not necessarily. Depends on how severe it is.
Old Jul 11, 2009 | 07:54 PM
So how can I know besides a tear down?
Old Jul 11, 2009 | 07:56 PM
pmohr's Avatar
No more Maximas...
If it's not that bent, you couldn't.
I've seen some that weren't visibly bent until you held a straight edge to them, or laid them down next to a perfect rod.
Old Jul 11, 2009 | 07:59 PM
Can I drive with it if it is that slightly bent?
Old Jul 11, 2009 | 08:02 PM
pmohr's Avatar
No more Maximas...
Yes, the ones I've seen were only torn down as core motors or rebuilding as a 'project', absolutely no complaints about driveability as far as I'm aware.
Old Jul 12, 2009 | 12:53 PM
Could I use a stethoscope to possibly hear anything funky in that cylinder, or am I just being paranoid?
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
