Water in Catch Can
Old Aug 12, 2009 | 06:19 PM
Wheelie King's Avatar
Water in Catch Can
My oil catch can seems to be collecting dirty water instead of oil. The oil on my dip stick is fine. I haven't changed the oil to see what it looks like.
Any ideas what could be causing the water in the catch can?
Old Aug 12, 2009 | 07:42 PM
Col Ronson's Avatar
well the product of combustion is carbon dioxide and water
Old Aug 12, 2009 | 09:36 PM
jh15's Avatar
What is a catch can? I've searched, at least in 5th gen forum
Old Aug 13, 2009 | 01:26 AM
CMax03's Avatar
I would think it's simple water vapors especially if your in a high humid region of the country. Since air is drawn into the engine's (PCV system) and thru it. I'm sure it's simply humidity...
Old Aug 13, 2009 | 01:55 AM
shadyonedeath's Avatar
http://forums.maxima.org/4th-generat...ome-depot.html
Old Aug 13, 2009 | 06:57 PM
Unklejoe's Avatar
There is an extremely far out chance that your headgaskets are bad and coolant is getting into the crank case and then evaporating when you run the engine causing the water vapors to come out through the PCV valve.
Im not even sure that that's possible though.
Old Aug 13, 2009 | 11:10 PM
CMax03's Avatar
He would see that with his dip stick if there was coolant leaking past a head gasket! I call it the loco mocho when you get that brownish whipped cream on your dip stick!
Old Aug 14, 2009 | 08:52 AM
bladerunr's Avatar
I live in Charlotte, NC and I've had a catch can on for over 2 years and i've never seen anything but dark black dirty oil in it. Unless other folks in high humidity areas have seen the light brown oil mixture in their catch cans, i don't see high humidity as a culprit.
there are so many varying factors that it's hard tell the reason unless the mixture is tested.
Old Aug 14, 2009 | 09:53 AM
foodmanry's Avatar
Da Roller Coaster!
Bong water.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
RWCreative
Sep 21, 2015 11:01 AM
