1995-1999 eFan Wiring Question
So I am going to ditch the belt driven radiator fan on my 300zx and install an e-Fan. My primary reason is to allocate more room infront of the engine to work in. Right now, I can barely fit a socket wrench in that area if I had to perform any kind of work there. I would have to basically dump the anti-freeze, disconnect the radiator hoses, and remove the radiator and fan shroud to have room to work in. I've already installed a 4th gen Maxima radiator which bolted onto my Z w/o any issues. I acquired a 1997 Maxima efan from a local wrecking yard. I am going to run the fans off of the Z's ignition circuit. Does anyone know the color code designation of this efan? I realize that this is a 2-speed set-up, I'm not sure which wires to use. I would like to wire the efans in such a way that its always at high speed. I would really appreciate any help from anyone that can tell me which wires to use.
Here is the pic of the wires on each efan motor:
The Frye
Sep 2, 2021 11:03 AM
