How do I remove the light that illuminates the ignition switch?
Old Aug 19, 2009 | 07:30 PM
1hawaii50's Avatar
Does anybody have any idea on how to get to the light that illuminates the clear ring that goes around the ignition switch? I am trying to change all of the lights/leds, but I have no idea how to get to that one.
Old Aug 20, 2009 | 03:41 PM
cfr94's Avatar
Same here. All other (interior) lights have been changed. I know the black ring comes off but other than that, I am stuck too. 1hawaii50, do you know if it takes a standard '194' bulb??
Old Aug 20, 2009 | 10:00 PM
morteljc's Avatar
+1
Old Aug 21, 2009 | 06:19 AM
1hawaii50's Avatar
It looks like a regular bulb, but it may be an LED on a circuit board...I can't get a good enough look at it to tell. I'll be pulling the speedo cluster out this week, and I'll see if I can get a better look at from that angle. On a side note, some guys on the other org said to be extra careful when "messing" around with the ignition switch as there is a delicate antennae in there that is needed to start the car, and if you damage it, you'll be screwed. If I can figure it out this week, I'll post back.
Old Aug 21, 2009 | 05:58 PM
cfr94's Avatar
Sounds good. Keep us updated. I might try to mess with it on Sunday as well.
Old Aug 21, 2009 | 07:16 PM
morteljc's Avatar
i'll wait..lol
Old Aug 21, 2009 | 07:29 PM
jh15's Avatar
This is a good find for me. Being an astronomer, I have red dome and trunk lamps, but the bright green circle on my '01 needs to be covered. Like others, I am wary about poking around there until I figure out my 'new' car. (A hand me down from wife buying new Altima). I'm willing to poke around, and ideally hack the antitheft just to prevent my own inconveniences. The thieves know more than us.
Old Aug 22, 2009 | 02:28 AM
1hawaii50's Avatar
Just from looking up from under the dash, it looks like the wire harness going to the lit area is plugged into a bulb-type socket...this would be good news meaning a simple bulb change. On the other hand, if it is a circuit board, that means soldering on a new LED.
Old Sep 15, 2009 | 02:16 PM
Firesice18's Avatar
It is a little wedge style bulb with a colored condom over it. I found this out while I had my dash gauges off doing an LED swap. You can reach it from the top if your gauges are off quite easily.
Old Sep 15, 2009 | 07:46 PM
cfr94's Avatar
That's good to know, however how do you get to it without the gauges / dash off?
Old Sep 16, 2009 | 02:28 AM
1hawaii50's Avatar
You probably won't. If you pull the speedo cluster, it's very easily accessible. Without pulling it, I could see it, looking up from under the dash, but there is NO WAY to get to it. You want to be very careful when "messing around" in that area, as that's where the antennae is located to allow you to start your car (senses when the key fob is present). If you screw up that antennae, then you are looking at a very costly repair.
Old Sep 16, 2009 | 12:50 PM
1hawaii50's Avatar
OK, here are the pics! This is the stock bulb. You'll notice the white plug near the center of the first pic. The second pic shows the bulb after I removed the orange condom.
Here's the blue LED I replaced it with!
Old Sep 16, 2009 | 12:52 PM
1hawaii50's Avatar
Old Sep 16, 2009 | 01:23 PM
Trakteam's Avatar
Nice.
Old Sep 16, 2009 | 01:48 PM
nyana107's Avatar
very nicely done my friend. what bulb size was used?
Old Sep 17, 2009 | 12:14 PM
cfr94's Avatar
Originally Posted by 1hawaii50
EXCELLENT choice in color. The blue on grey looks awesome. Would you be willing to do a write up on how to get the dash off so others can do this. I leave the 19th for Iraq so I don't see me getting this done but when I get back....it's on like Donkey Kong. PM me the instructions and a good write up if you don't mind that way I dont' have to go lookin through all the threads to find it.....i mean if you would kind sir.
Old Sep 17, 2009 | 01:19 PM
1hawaii50's Avatar
God bless, and stay safe in Iraq! For a bunch of great how-to's, check 6thgenmaxima.org, they've got a great write-up for the dash removal.
http://www.6thgenmaxima.org/forums/viewtopic.php?t=5715
Under the "useful information" section, there's a LOT of great info. If I can help with anything, please let me know.
Old Jun 24, 2010 | 04:32 PM
mrkhone's Avatar
anyone know where i can get the trim around the key ring. i don't have one
Old Jun 24, 2010 | 05:05 PM
1hawaii50's Avatar
What year is your car? What happened to the trim?
Old Jun 25, 2010 | 04:12 PM
mrkhone's Avatar
i have an 04. i swore it was on there when i bought the car then just one day i noticed it looked funny. realized the trim was gone. now it just looks funny. any place i can get one.
Old Jun 25, 2010 | 08:02 PM
1hawaii50's Avatar
What exactly are you missing? Mine has a flat trim bezel that is the color of my interior. The bezel goes around the illuminated plastic, which goes around the ignition. Take a pick of your ignition and post it here so we can see exactly what you have going on.
tsi6001
Oct 3, 2022 10:23 PM
trasmadean
Jan 20, 2018 05:05 AM
kmitchel
Oct 28, 2015 09:46 AM
rbaker100
Aug 28, 2015 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
