Hids Flickering?
Old Aug 25, 2009 | 11:55 AM
x X CLoud X x's Avatar
Hids Flickering?
question just got new hid's installed and when there being turned on it flickers for like 10secs then it stays on, anyone had this happen and know whats causing this, thx
when both the hids flicker its also causing the aftermarket headunit to flicker to but once hids stop flickering, the radio is fine
can it be the old battery?
Old Aug 25, 2009 | 12:55 PM
maxgtr2000's Avatar
KH3 by popular demand
If the battery is old that could be the problem, if it is burning up up there in NY check the battery fluid level. If your kit is aftermarket that could be an issue, if it is an oem kit then check your ground connection. When I had my hids grounded to the frame it would flicker but once I connected a ground straight from the battery it stopped doing it.
Old Aug 25, 2009 | 01:47 PM
queenambeach's Avatar
Could be a grounding issue, could be your alternator going out, or it could be that your factory harness isn't up to the job. Get a harness powered directly to the battery.
Old Aug 25, 2009 | 05:53 PM
fourstaroots's Avatar
happened to me and my alternator died!!
Old Aug 25, 2009 | 06:07 PM
anomaly117's Avatar
did you disconnect your neg battery terminal while installing the HID kit? if so make sure you tightened it on well enough and theres a good connection. especially if the battery is "old"
Old Aug 26, 2009 | 07:04 AM
JtzMax's Avatar
Whatchyou say?
That is the process .... lmao! All HIDs do this, it's a gas that ignites and it warms up to operating temp at the 10 sec mark.
Normal ....
edit: sorry ... I'm a tard, just re-read the OP. It may be a battery issue, or a harness issue. You can test the alt a couple different ways. Easiest is to go the the parts store and ask them to do it on the spot - most can / will.
Old Aug 26, 2009 | 07:50 AM
Bassbreaker's Avatar
I was told that if they are aftermarket, to buy a relay kit and hook your hid's up to it. It will draw straight from the battery rather than the electrical system. They are only like $25 and would more than likely solve your headunit flickering issue to
Old Aug 26, 2009 | 08:02 AM
anomaly117's Avatar
dual beam HID's come with relays built into the bulbs. i determined this while troubleshooting my kit. its only possible to wire in a relay on single beam HID kits.
Old Aug 26, 2009 | 08:04 AM
holymoly's Avatar
HIDs are great but only last one year for me.
Old Aug 26, 2009 | 08:30 AM
But they're still drawing power from the factory harness which is a no no. The relay only acts as a switch to tell your bulb to start drawing power from the battery...........shouldn't matter if its a single beam HID or not.............
Old Aug 26, 2009 | 08:36 AM
anomaly117's Avatar
mine are wired directly to the battery, they only receive power on signal and high-low beam switch signal from the harness.
it also seems to me that it would be a PITA to wire it to dual beam bulbs, youd most likely need 4 relays.
MaxLife17
Jun 27, 2019 01:37 PM
mikeg75
Nov 30, 2015 05:12 PM
foodmanry
Sep 24, 2015 12:02 PM
Vistance
Sep 17, 2015 05:17 AM
Maxima30
Sep 7, 2015 06:13 PM
