UPDATE: NEED HELP! Car Dies When Coming To A Stop
Well, cleaned the MAF, but still stalls at a stop.
The weird thing is that the car DOESN'T stall unless I shut the car off after the first start-up and then restart again soon after. For example, if I start the car up after a long cool down period (overnight, or after work), I can drive it without a stall. But if along the way I make a stop, say, at the store, then start-up again, the car potentially starts stalling when I brake at a stop light. But after that, it would fine.
No CELs, and ambient temperature is low 50s to mid 60s.
my 5th gen does the same, when coming to a stop it just shuts off, no forewarning no nothing. i asked a friend about it and he said to clean my TB, so i did...seemed to work, but didnt when i found out this sunday when coming to a stop it did the same thing...that was about a 3wk period until it did it again...if there is anything new on this subject i'd gladly appreciate the info. thanks in advance
IACV have any electrical contact points. Try cleaning those and for MAF electrical contacts as well. Might need a new MAF or IACV. Its a fuel or Air delivery issue. Somethin either isnt delivering fuel or air at idle.
Try adjusting the Idle by shortening the Accelerator cable at the TB. Let the car idle at 800-900 rpm instead. Jus as a patch fix until u can really find tha culprit
IACV = Idle Air Control Valve: If I remember correctly, it's the solenoid that sends the computer information to adjust idle speed, that's about it...
MAF = Mass Airflow Sensor (the way too pricey part on our cars): Measures air intake to get to the right air/fuel ratio.
where is the iacv and how do i clean it?
PLEASE, SOMEONE WITH PICS OF THE IACV POST THEM, I HAVE SEARCHED THE 4TH AND 5TH GEN FORUMS FOR PICS/LOCATION OF THE IACV TO NO AVAIL, EVERYTIME SOMEONE ASK IT SEEMS THAT EVERYONE LEAVES TEH THREAD AND NEVER RESPONDS EVER AGAIN
The IACV is located to right of the throttle body. The upper right hose on the airbox connects directly to the IACV.
This writeup gives clear pictures and instructions on how to clean the IACV along with several other parts:
http://forums.maxima.org/4th-generat...g-dummies.html
You'll find those instructions and many of others in the HowTo's: 4th Generation Maxima thread.
Crazy. I had some serious issues with my maxima not idling and wanting to die all the time (I had to keep the rpm higher than usual) I had my brother look at the car and turns out there was a ****ty gasket and the engine wasn't getting enough air. Fixed the problem immediately after changing it. Car idles perfect!
Here are additional symptoms I noticed related to the stalling:
1. Preceding the stall, the revs would just fall to near idle when I lift off the throttle. I can be in 5th gear (AUTO) and it's still fall like a rock. Most of the time it works fine.
2. It seems to begin acting up if my route/drive involves a large amount of braking. On the freeway, no apparent problems, but in stop-go traffic, you can feel the revs begin to dip gradually at idle.
So can anybody tell me that if the MAF is the most likely culprit, why does braking cause this whole problem?
Stalling like this is dangerous and is driving crazy, because I never know when it'll happen next.
Careful with the MAF though, those are delicate and expensive..
And just so you know for future refrence. Our Auto tranny's are 4 Speed's the 5th Bump you feel is the TC locking up...
hey man, defintely do these first...
Uh Oh, dude do you have mysterious lights coming on in the guage cluster? for example Battery light, air bag, ect? I think your charging systems ****ed go get it tested. some places will do it for free.. idk where tho. ive only heard.
Nope, no strange lights. I had a brake light but that's surely due to my crapped out rears.
hmm, se thats peculiar.. Cus the window motivators i know drain a bit of current and always have dimmed headlights. Now your car dying rolling the window down... makes me wonder... really go have your charging system tested just to be sure.. unless you KNOW its good.
So could be the alternator? My batt is new.
They are all located in the same area and may even be the same valve as the IACV. They jus have a different control loop to control function. Im not sure tho so dont quote me....but they definitely in the same place.
Silly question too...but u change PCV lately??
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
