What causes fuel injectors to die?
I did a little searching and really didn't find anything except that bad gas will kill them quickly, but ive had 3 injectors go out on me in 6 months and i have 105k. What would cause them to die to quickly?
I dont use bad gasoline either its always 93 Octane Shell or Hess only
It's really odd that you keep going through injectors, especially since you use high octane gas only. They tend to fail if they get gummed up, but I don't see why they would be unless maybe your running lean or rich? I'm not 100% sure on that though (someone correct me if I'm wrong).
Every oil change you should put some SeaFoam in your gas to clean out the injectors and keep them clean.
Im wondering if the electrical wires are corroded or the contact points jus need to be cleaned. I mean, mechanically they are rather simple, and shouldnt be failing that rapidly. They jus need an electrical signal for correct firing timing. Im wondering if Fuel Injection Distributor (not really sure what its called) is malfunctioning instead
well i used an ohm meter to test them. one tested out at 16 ohms so i replaced it and i had another that didnt even measure so i changed that one...i have three spare injectors now just in case lol
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
maxima297
Sep 30, 2015 03:32 PM
