Sun roof and radio/temp light problem..
Ok well all of a sudden my sunroof just started to act funny.. When i try to open it, it only moves like 2 inch and stops.. I tried disconnecting my battery but that didnt work..
Now after that problem now at night time when I have my clock light, my radio and temperature lights dont come on.. wtf??
My foglight are not coming on also witch is pretty weird. I do have them wired to my tail lights but the tail lights work. I haven't worked on my car for a while.. I'll have to check the fuses in the morning.
EDIT: also when i try to dim the cluster light it will not dim..
Why does your fog light wired to your tail light in the first place?? Doesn't make sense to me... I would undo every wire and set back to orginal. If that doesn't work. I would post this question in 5th gen section and someone might be able to help you out.
I did the foglight re wire to the tail light fuse under the hood.. I'm pretty sure it might just be a blown fuse somewhere but IDK where. This is pissing me off cause my tail lights dont come at night unless I use my brakes..
Oh I see. I would recheck that fuse box. Where did you get the instruction from? There is a good link. http://www.shiftice.com/fog_rewire.html
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
