Need Info How To Run Wire To Battery From Amp
HOW CAN I RUN A WIRE TO THE BATTERY, WHERE IS THE FIRE WALL,AND IS THERE A WAY TO AVOID CUTTING THRU IT, OR DRILLING, IS THERE A WAY TO RUN THE WIRE
HOW DO I FIT 6'9'S IN THE BACK, I NEED TO FIT THEM
I ALREADY BOUGHT THEM HEHE
94 MAXIMA..
94 MAXIMA..
The fire wall is the big fat heat shield that sits between you and your engine, all it is is a big hunk of metal, probably some synthetics in there too. You could look for a grommet in your firewall to pull the wire through, in case you don't know what a grommet is it is a usually a piece of rubber or plastic that protects wires or cables running from the engine compartment to the inside of the car. When you look in there you should see what I am talking about. An easy place to run a wire is would be where your radio's power cable is , or even through the grommet where the clutch cable is, if it has one. As for the 6x9's you should've bought 6½'s, J/K I am really fond of 6½'s, I wouldn't know, but someone else should.
Re: Need Info How To Run Wire To Battery From Amp
dont type in all caps
94 MAXIMA..
94 MAXIMA..
94 MAXIMA..
94 MAXIMA..
good luck
Originally posted by NICOLE
just drill a hole throught the fire wall it is a very quick and easy.and once u made the hole make sure that u seal around the wire just in case u made the hole 2 big
This peson said they didn't want to drill.
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
Viralkill
Aug 17, 2015 10:54 AM
doobadoo
Aug 15, 2015 06:43 PM
