Horns. what do you have?
Old Feb 15, 2010 | 08:16 PM
SLOW2KMAX's Avatar
My 5.5 gen was broke into a few months back and stole my avic d3/sub/amp smashed both windows and f'd up all my wiring. All has been fixed. But that nite/am it happened i didnt so much as hear my alarm go off 30ft from my window. I ditched the factory alarm and was wondering what people are replacing there horns with. I was looking around at air horns but really dont want a compressor in my trunk to power it but didnt really find a "bolt in" replacement. Anyone reccomend something loud?
Old Feb 15, 2010 | 09:34 PM
The6spdMax's Avatar
So you took out/uninstall the factory alarm? And now you don't have a remote/alarm system? If you want a good security alarm system, just go with aftermarket security system like viper and other good brands, they have their own horn and its loud.
Old Feb 15, 2010 | 10:04 PM
Mr. Brett's Avatar
You can get a small 20-25 PSI compressor that would probably mount right up in your engine bay for a set of airhorns. A member around here has a setup like that. I forget who. But he apparently loves it.
Old Feb 15, 2010 | 10:09 PM
Froggmann's Avatar
If you are looking for pure decibels for cheap you will want to get a set of Cadillac horns. If you look around for one of the older, higher end caddys you will find four horns on them their tones are A, C, D, F and all together sound like a train is coming.
If you are looking for something that will catch someone's attention and generate looks you can pick up a cheap Ooooga horn. I have one on my Bronco and when someone does mess with it and the sucker goes off they just bolt. They do have a pretty good decibel range to them but they aren't something that people are used to hearing anymore.
Another suggestion is to get an ultra-loud siren and mount it to the inside of the car, that way even if they drop your window and get in they won't want to stick around. If they do they won't be able to hear **** for a week.
Old Feb 16, 2010 | 04:14 AM
2slow's Avatar
Hella Supertones
Old Feb 16, 2010 | 05:24 AM
1997MAXZ's Avatar
Originally Posted by 2slow
Hella Supertones
do they sell a direct replacment for our maximas that plugs right up to the stock horn harness??
Old Feb 16, 2010 | 05:51 AM
Shift_Max's Avatar
I also have Hella Supertones but they are not plug and play
Old Feb 16, 2010 | 06:43 AM
SLOW2KMAX's Avatar
I ditched the factory alarm and have a Viper 5701. It works just off my horns as the alarm. The installer never hooked up the siren it comes with. I was just debating hooking that up and seeing how loud it is mixed with my horns.
I was searching around and really couldnt find much besides a $250 kit that has a 1.5 gallon compressor you mount in the trunk from hornblasters.com
Thanks very helpul info. I will look into the caddy horns. like i mentioned above the installer never hooked up the siren that came with the viper alarm i have so may just mount that up uner the hood or inside the car somewhere. Thats a good idea. I have glass coverage so if they break a window oh well lol.
Hella Supertones
I was looking for something a little louder. They only generate 115 decibels when stock is like 97 i believe.
Old Feb 16, 2010 | 07:20 AM
Mr. Brett's Avatar
You might have more luck looking for a compressor at your local hardware store. It would just be a matter of finding the horns elsewhere after that. But yeah, the Caddy horns are a good alternative, too.
Old Feb 16, 2010 | 07:54 AM
rvamaxima's Avatar
Sound increases exponentially, 115 is pretty loud. Here's a pic of my set up. They wire directly into the existing wiring, you just have to extend the wire from the internal horn.
Old Feb 16, 2010 | 08:23 AM
mandyfig's Avatar
How about some Denso or Bosch ones. Just like in the Lexus. They are loud.
Old Feb 16, 2010 | 08:48 AM
SLOW2KMAX's Avatar
anyway to add them to the existing horn so you use the 2 stock and those? i was thinking of using these-http://www.myhotmaxima.com/Hot-Rod-Deluxe/Air-Horns/Chrome-Hawk-Electric-Horn/675205/
along with the stock horns or the ones posted like yours. a little overbored but still cheaper then a full on air horn kit. also with both blowing 115 decibels and different sound its sure to get some attention.
Old Feb 16, 2010 | 08:53 AM
digitalbow's Avatar
Interesting that you mention this. I have a set of these from an '89 in my Altima. We tig welded them onto a custom bracket that attaches behind the impact bar, where all four horns face downward and seem to project their tones much better than the OEM locations. While I used the OEM relay, I recommend delving into the specs and ensuring that you match the intended power draw appropriately. I'll have to dig up a picture, but here is a a quick snapshop with sound: http://www.youtube.com/watch?v=IJYI4c7Wv44
Old Feb 16, 2010 | 09:06 AM
rvamaxima's Avatar
The amp draw may be too much for the 4 horn without using the relay included with the horn kit. You could tap into one of the existing horn wires to signal the relay. You would have to find a different location for the hellas if you keep the OEM horn behind the grill. My second choice was to attach them to the lower radiator support.
Digitalbow- that sounds awesome, behind the impact bar is a nice place to mount them for protection.
Old Feb 16, 2010 | 09:23 AM
SLOW2KMAX's Avatar
i thought it might be a little to much draw but like you said if its wired correctly with relays it should be fine. I have no problem mounting the extra set of horns so i think thats what i am going to do.
Old Feb 16, 2010 | 09:26 AM
mandyfig's Avatar
The existing horns have relays on them, for a swap, it should be plug and play.
In fact I have a set of Bosch horns that I want to replace my OEM's but I can not seem to get my horn going if I wire it directly to the existing taps. I need to investigate further.
Old Feb 16, 2010 | 09:51 AM
MadMax07SL's Avatar
Dude, 115 is pretty f'n loud. Compare here:
http://www.gcaudio.com/resources/howtos/loudness.html
Old Feb 16, 2010 | 09:55 AM
SLOW2KMAX's Avatar
lol yea ive realized that after hearing horns. It is pretty loud.
Old Feb 16, 2010 | 10:05 AM
1997MAXZ's Avatar
dude, i want my horn to sound like that, 89 cady you say, witch model, will it be hard to do.??
Old Feb 16, 2010 | 12:47 PM
mandyfig's Avatar
An install pic would really help us out!
Old Feb 16, 2010 | 03:22 PM
Froggmann's Avatar
The Junkyard is your friend, Caddys and Lincoln MK VIIIs because of the air-ride setup have pretty powerful little air compressors. From what I understand they generate enough pressure to drive Semi truck horns. Just another idea.
Old Feb 16, 2010 | 07:03 PM
digitalbow's Avatar
Thanks. They came from a DeVille. Only some of the later models had a 4-tone setup, as an option too. The only difficult part is figuring out a way to mount them. Froggmann is correct, that it is an A, C, D, F. Good luck.
Old Feb 16, 2010 | 07:38 PM
SLOW2KMAX's Avatar
I'm going to the junkyard tomorrow to see what they got. Thanks a lot for the info.
Old Mar 29, 2010 | 10:49 AM
mandyfig's Avatar
Just installed new Fiam Electric Horns. Dumped the OE ones and installed it in the air dam. I will create a new thread and DIY with pics.
Man, they sound good!
Andy29
Jun 4, 2015 10:27 AM
streetuner
May 7, 2010 10:06 AM
OutMaxxed
45
Feb 25, 2007 08:49 PM
Metal Maxima
Aug 21, 2006 08:46 PM
Teser
Aug 19, 2003 09:58 PM
