95 Maxima CYL 1 will NOT fire. Please help, need car!
Hello,
I have a 95 maxima with 79k. it ran amazing until this morning. cyl 1 will not fire. replaced coil with brand new. Still will not fire. Plugged cyl 3 harness into "bad" cyl 1 coil, and it fired the coil. I use a test light and it lights up the red wire, with the ignition on. im going to search this forum, i need the car! please help!
thank you
thank you
is the harness being busted a common thing? should i just go to the JY and pull a cut a new harness and splice it on?
if the cyl1 injector was shot, the coil would still fire right? i pulled the coil and plug out and started it, and the plug did NOT fire.
It sounds like to me that u are not getting signal to that harness. If u have already replaced the cyl 1 coil (with a NEW one) and the plug still does not fire that its an electrical issue. Meaning a wire shorted out somewhere. I would proceed to the harness and check resistance across the terminals for a short. See if u can rewire it. If that dont work then the wire shorted out somewhere. If that is the case then your best bet would be to trace that wire back to the origin, clip, and re-wire
The injector should be fine.
had no resistance. got a new condenser, it fired, now go fuel. pulled the upper manifold, injector was shot too. no resistance either. should be back together tomorrow. thanks a lot of your help
put a lil oil on there and tapped her in, no problem. about to put on the uim, but i cant figure out where the 1 vacuum line goes on the back bottom of it(back at the fire wall driver's side T fitting)
Lakersallday24
Jun 16, 2019 01:35 AM
MikesChevelle
Aug 6, 2015 11:36 AM
