$300 super charger option
http://www.electricsupercharger.com
1psi of boost
4-12 HP gain
WOW! What a bargain for such terrific gains!!!
1psi of boost
4-12 HP gain
Originally posted by emax95
I never heard of this thing before. Does it actually add HP?
I think it is a problem of 12 volts not being enough to produce usable boost. Any electrical types know if it would be possible to wire a second (or third) battery (or capacetor) in parallel to increase voltage and make an electric supercharger that really works?
It sounds like a silly product. It only activates at WOT, so unless you regularly floor the gas pedal, which would be a dumb thing to do in a Max from a standstill since the front tires would just spin and smoke up.
Unlike a real SC, where you have extra power all time, regardless of throttle position.
Originally posted by Anachronism
No, there are a couple of old threads on it, search. Someone actually lost a couple HP with it.
Yeah you would loose HP if you wired it backwards
Originally posted by ereet
Better cheap supercharger:
Find some guy really hard up for money, sit him under your hood, have him blow into your air intake tube for $20 bucks. Wheee!
Originally posted by 93_MaxSpeedMark
I looked at the demo video, and the thing actually flies outta the guys hands...I think i'll be the guinea pig...It couldn't hurt, and if it does, I'll just put my CAI back on.
well, if you ever get it, be shure to tell us what u think about it
Daniel B. Martin and I did a little research project talking to fan and blower vendors trying to find out what kind of power usage and fan types to create a constant 3-9 psi in the intake manifold threshold. Basically there were 3 companies that could make these fans on a 12 volt power source, but it would cost nearly 5k. One company said they could do it cheaper but feared that the cost savings would leave you with less than optimal bearing and motor. Leaving it with a short spin life, maybe 100-200hrs. So it's possible, but not realiable for an application such as ours. Sorry.
From the research that you've done...
Could a more reliable and/or less expensive blower be made with a 30v or even a 42v source?
No we didn't, we were only looking at it on a bolt on feature for the common car. The biggest problem was that the motor would have to be pretty small or have it belt driven off of a satelite motor. And there are motors and fans that will move that much cubic ft of air but the motor would have to beable to spin the rotors at like 25k rpms a minute or more. to provide that 3-9lbs of pressure. Plus when you had it turned off it would restrict air flow. So in time I would assume that technology might allow it to happen, but its not there yet.
NOW if you want real genuine front wheel horsepower and low end torque,simply take off both windshield wipers,throw away the driver side wiper and raise the passenger side wiper to give you the "1 wiper effect" i have heard gains of up to 12 hp and 14 ft lbs. of torque from this mod
Originally posted by costcowholesale
get like a 100000000000000000 feeet hose and suck it to his mouth an d the intake, have it blow air @ home
Originally posted by Rancid90SE
yeah thats not a bad idea,but when you mount this guy under your car to blow his warm breath into your intake,hes gonna weigh at least 150 so you would (according to the 100lbs=.1 seconds rule) would probably end up slowing your car down
As for the wipers, we all know that driverside wiper weighs a good 300lbs. Why else would people do that?
ok.. for the simple fear of ridicule i wasnt gonna post this earlier. i was trying to figure out the best way to mount a 120v motor, such as a small leaf blower or a shop vac engine running through the intake. so i did alot of looking around , even went out and bought the perfect motor for the project i had in mind, until i found this site.. give it a look and tell me what you guys think. i was glad to see i was at least not the only moron with the idea, but not for nothin, it seems to me that he had more of an electrical problem then anything, so im still wondering.. if any one is serious about tryin to do somethin like this i have alot of good ideas so feel free to ask..
http://www.bimmers.com/m3/hoax/index.html
Originally posted by Ant95se
it seems to me like a joke ..
the guy didn't really cut a hole in his M3...
Ant
Ant
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
