ran into problems installing oovi, gurus please help my noob arse
ran into problems installing oovi, gurus please help my noob ****
ok so i had a oovi kit sitting in my basement for god knows how long and I thought it was complete. So i start stripping my 99max everything is going ok. I put on the new valve covers then notice that i only have half of the 00vi injector harness. I have 3 injector harness' now.
this is what im thinking, modify the 99 injector harness to fit the new injectors??
one other thing, i cant find the thread that tells you what to buy from home depot for the IACV adapter plate.
As always i appreciate any help, flames are welcome cause this is a noob problem!!!
o great i just noticed its not a VAFC i have, its just a msd digital window switch PN 8969
Should i just go with the 4thgen lower, gonna break out the drill if you guys say so
I had my 00vi drilled. It worked great and requires less of a tune. Well im just guessing it requires less since it already runs a bit rich stock so adding more air to the mix should (in theory) make the a/f ratio better.
crap i lost one of the rubber o-rings for the lim that holds the injectors, gonna run to auto zone to buy some fuel line and im gonna try to find one of the o rings at home depot
hmm lets see, i dont know how easy itll be to find clips, but if u find a way to modify urs let me know, cuz i have a friend in the same predicament, only 3 clips. you *may* be able to find some little connectors to put directly on the injector pins, but it would suck if they touched eachother, so idk about that. maybe solder them for the time being? once again, risky i think.
as far as the iacv, i dont think many people have tried to make their own plate out of home depot parts. i have seen one, but it looked like a bit of work. id just use the 5th gen iacv for now and if you must, then find an adaptor. i have zero issues from my 5th gen iacv.
sorry i should have been more specific in my first thread. i have the triangular aluminum adapter plate, i dont know which parts to buy from home depot to put it on though.
i decided im just gonna drill the 00vi to fit the 4th gen lim. im gonna go buy 6 4th gen injectors tomorrow. god damn rubber o ring@@!!!@
you should probably have them welded shut because jb weld can break off in the engine.
if anyone else has any other ideas as to how to fill the holes let me know because im in the process of doing my 00vi as well
^nice i was just thinking about getting an old bolt with locktite and dremmilling the top off, wow + 1 for hornypirate
so this is gonna be my set up
00vi
4th gen lower
00 iacv
4th gen fuel rail and injectors
00 throttle body and 00 tps. Gonna have to adjust it when i get the car running. My 99 one was crapping out
and im gonna remove my egr and block that suka off
cant really find good picks on how to make an egr block. any1 got any ideas? i dont want all that crud to get into my im
00vi
4th gen lower
00 iacv
I just cut the tube off right at the bottom portion of the guide tube and screwed a bolt into the chunk that was just cut off.
Heres a pic of the part that is not going on the car...I cant get a good pic of the blockoff on the car.
i blocked of the egr using a quarter and jb weld. hasnt failed. lol. i sealed up my stock bolt holes with jb weld. worked great cause even if it does break its not going to go in the engine. its going to fall by where the knock sensors located which is harmless.
00vi
4th gen lower
00 iacv
00vi
4th gen lower
00 iacv
you have to leave the sensor hanging in the engine bay so no code will appear and Nissan sells a plug for the exhaust manifold I can't locate the part number. Also what could be done is to take a couple sheets of aluminum using an EGR gasket and bolt the aluminum with the gasket o the back of the manifold.
No ideas yet how to block off the exhaust manifold portion of the EGR
I still have 10.8:1 AFR non-tuned between 5500 and 6500rpm after the VI transplant.
[QUOTE=hornepirate;7473843
No ideas yet how to block off the exhaust manifold portion of the EGR[/QUOTE]
Buy the egr plug from the dealer on 2000-01 models. But be very sure that you use the right socket to remove the egr guide tube on the rear manifold, if not it'll strip (dont ask be how I know!!!lol) be sure the socket is very solid on the ''nut'' then unscrew with air tools.
'question for vqed' do i really need air tools? i cant use a cheater bar?
This is how far i am so far.
I got the whole 4th gen im off. I got the new valve covers on, but i have to take them off again cause i forgot to run sealant round the gaskets, rofl.
I have not removed the VIAS system, or the EGR system yet. Those are the next things on the list to do. After that im drilling the the 00vi im to fit on the flipped 4thgen lim. Then im gonna start drilling wholes for the brake booster and then drill the little mini hole on the left side of the 00vi. I have titanium drill bits thanks to my dad so thats gonna cut thru this like a hot knife through buter.
he left me all of his tools, may god bless his soul.
-RIP dad 10/18/09
-RIP dad 10/18/09
Check this site:
http://tatanko.boredmder.com/
also, you can contact krismax, he's the father of the 00VI.
-RIP dad 10/18/09
-RIP dad 10/18/09
sake1bs
Sep 19, 2015 09:32 PM
