Wheel + Pothole = Dent ... Can this be fixed ??? (With PICS!)
Old Apr 5, 2010 | 10:02 AM
EriCCirE's Avatar
Hey guys check out these pics and let me know if you think the wheel can be repaired.
The tire when filled also balloons out above the effected area.
I know I'll need a new tire. Can my wheel be salvaged? Where do you recommend I go for this sort of work?
Old Apr 5, 2010 | 11:02 AM
tigersharkdude's Avatar
yeah that can be fixed. It doesnt look to bad. Call around to local wheel shops and ask about fixing a bent wheel
Old Apr 5, 2010 | 12:21 PM
ajm8127's Avatar
I'm curious because I just put lower profile tires on with new wheels and I live in PA. What tire pressure were you running and how fast were you going?
I gotta say when I first saw that pic I thought for sure that wheel was done, but tigersharkdude seems much more optimistic. Goes to show you what I know about wheels.
Old Apr 5, 2010 | 01:10 PM
EriCCirE's Avatar
was traveling about at 25mph and the tire was at about 30 psi ( a little low)
Old Apr 5, 2010 | 01:36 PM
vball_max's Avatar
Where are you located? That may help get you specific shops instead of "go to a wheel shop".
Old Apr 5, 2010 | 01:50 PM
Cliff Clavin's Avatar
Way out West
I had a forged centerline wheel that bent like that on the inside area only and it was not fixable. I checked local shops first and I even shipped it to a place matt93se recommended and they shipped it back saying they couldn't fix it.
I don't know if this was because mine was forged, though.
Yours looks worse than mine and yours looks like the entire "barrel" of the wheel is bent, not just the outer lip portions.
You should definitely check around or send pictures to places that specialize in wheel repair. It might even be cheaper to just get a replacement.
Old Apr 5, 2010 | 10:31 PM
IHAVEA2KMAXIMA's Avatar
Looks like the entire barrel is out of true... I'm no expert but that's pretty hard to bang it back to shape. If it was just the lip then its a whole different story.
Old Apr 5, 2010 | 11:43 PM
J2FRESH's Avatar
try them & they also sell dope wheels too
http://rbmotorsports.blogspot.com/se...Wheel%20Repair
Old Apr 6, 2010 | 05:20 PM
anhhuy8's Avatar
that wheel can easily be fixed. i had worst bends on my axis wheels before.
Old Apr 7, 2010 | 08:35 AM
Pullin3RD's Avatar
Word yeah should be fine
Old Apr 7, 2010 | 11:38 AM
SiathLinux's Avatar
This type of damage is why I think I'll be going with 3pc rims - so if I bend it out of shape I just replace the 'barrel' ...
I think on your rim it may be fixable if you find the right shop to work on it.
Old May 6, 2010 | 04:56 AM
Stalldaworld's Avatar
I Have an Axis hiro thats bent as well. I think its just the lip tho. Tire holds air fine, no bublles either. How much does this kinda thing generally run to get fixed?
Maxima_Joe
Nov 25, 2015 08:19 AM
tnewbs
Aug 28, 2015 10:15 AM
Balkins
Aug 12, 2015 06:39 AM
