Cheap/easy 75MM ID aluminum maf adapter
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Spectre 3" aluminum maf adapter roughly $15-20 if you order online. Measures about 5mm bigger ID than the stock maf adapter. The kit doesn't come with an adapter that fits our maf, so it must be made to fit.
Stock maf tube ~$15-20 used on forums, or free if you hack up yours. I just cut off the MAF adapter right where the screw holes end and then sanded it smooth and flat.
Used the black VHT ceramic paint. I would bake it if not for the plastic maf adapter.
Pardon my messy work bench
Taped off for painting (I like to keep a clean non painted surface for the couplers)
Paint drying
Finished
Paint drying
Finished
It is marginally less than the stock location. Maybe 1/16". I don't foresee any problems. I will have to adjust the A/F anyway.
I had the extra maf tube, and I got the maf housing off a friend for cheap... I have been considering what I would do with my MAF, and this seems like the best for the price.
sparks,
Two things:
1. I found 3M products that refer to CA adhesives. What type did you use and is it heat safe? I've gotten something I'd like to try (plastic to metal).
2. Would you think there would be any tuning needed if someone went to a complete 75mm intake pipe to throttle body? Or would the ECU compensate for the slight difference in increased air flow?
Two things:
TallTom
57
Oct 14, 2025 05:16 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
