spring isolator
Old Apr 11, 2010 | 04:36 PM
MAXIMA_STYLE's Avatar
spring isolator
Does anyone know where to purchase a set of new ones?? i may be buying a set of used lowering springs with no isolators figured someone here would know where to get new ones...
Old Apr 11, 2010 | 05:47 PM
CMax03's Avatar
I use those polyeruthane isolators from ES.... look thru their online catalog, perfect for the upper isolator and works well as a lower isolator....You can also contact Courtesy Nissan....
Old Apr 12, 2010 | 04:48 AM
knight_yyz's Avatar
Toolie
do you have the part numbers for those? I checked the energy suspension site and they don't have anything even close to fit a 5.5 gen
Old Apr 12, 2010 | 05:33 AM
CMax03's Avatar
It's universal p/n 9.6112 style E, perfect for the top but will work on the bottom as well.
Old Apr 12, 2010 | 04:15 PM
they wrap around the new springs???
Old Apr 12, 2010 | 05:31 PM
knight_yyz's Avatar
Toolie
ok, but those are not made for the top, only the bottom of the spring, there is a large rubber donut that is used for the top isolator.
Old Apr 12, 2010 | 06:42 PM
CMax03's Avatar
They are big enough that they actually fit better than the OEM top isolator....I'm using them on both ends....my ride, my choice, it's been like that for 3 yrs.....and I'll never wear them out.....
Old Apr 12, 2010 | 07:31 PM
nismopc's Avatar
I have Vogtland springs and there would be almost no way to slide that type of isolator on the top of the spring based on the design.
I know that my old Maxspeeds would have worked with these.
What about the style A?
They seem to be a good match and www.suspension.com states 9.6114 is used on may Nissan cars. I don't know the actual measurements of the Max, so can't confirm...
COILS_SPRING_ISOLATORS
Old Apr 12, 2010 | 08:49 PM
CMax03's Avatar
A-2 3/4"
B-3"
C-4 1/16"
D-1/4"
E-5/16"
F-9/16"
Old May 3, 2010 | 03:55 PM
ok so im still looking, how do these work on the springs? you just slide them over the spring?
Old May 4, 2010 | 10:26 AM
CMax03's Avatar
under the springs....
gigabyte
Jan 6, 2017 06:05 PM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
