3.0L Oil in intake manifold?? HELP!?
Alright so I've done a bit of searching for the answer but everything I find seems to apply to the 3.5L, I have the 3.0 5-speed
I just bought the car a while ago and do not have much experience with Nissans yet, I took off the Injen intake the car came with to give it a shine, and I noticed alot of grungy gunk in the trottle body. I figured it would be a good idea to take it off and give it a clean (and while I'm at it I'd polish up the metal with a buffer and make it look nice) I noticed it seems like coolant or something runs through the T.B which i havent seen before, so after getting the trottle body off I notice the intake manifold is disgustingly coated inside with oil!! Wayyy too much to be normal, does anybody know of this being a common problem with the 3.0 and a solution for this?? please help me!!!!!!
I want to make this a reliable smooth running vehicle so I think I'm going to pull the engine/tranny and give it a full tune up (belts, pullys, clutch, fluids, clean everything, gaskets) while I drive my winter beater
Don't get your knickers twisted......some oil in the intake in the area of the TB is normal, particularly if the car was romped on quite a bit (particularly with it being a 5 speed as well). The Injen intake which I believe eliminates the stock intake duct air supply hoses (3 total) connector box, doesn't help either. I would replace the PCV valve, mind you, if you don't have any record of it being replaced recently, and check the PCV valve hose and the crankcase vent/blowby hoses for any blockages as well. At idle there should be some vacuum at the end of the PCV valve. How many kms on this car? Like some other cars coolant was flowed through the IACV/TB to prevent icing. Remove the IACV stepper motor and check for any signs of coolant "under" the stepper motor. Ensure that the warmed up idle is a stable 575-675 RPM.
sorry I'm just really new to Nissans and V6's in general
foodmanry
Sep 24, 2015 12:02 PM
Mahmuth
Sep 17, 2015 11:45 AM
ag90fox
Sep 9, 2015 12:22 PM
